Hi Everybody!
I'm having a problem here I can't seem to figure out, hopefully I am just missing something obvious.
Ok...I have a Mackie Onyx 1640i that I run into my Macbook Pro. Until now, flawlessly.
I got an Apogee Duet recently and for conviences' sake I have been using that to record into my MBP.
Now the problem...I went to use my Mackie because I am getting ready to start tracking my band and I can not get any levels on my MBP.
The Apogee is disconnected, my MBP is reading and recognizing the Mackie, I have the channels pulled up on Garageband going to the tracks and I am getting NO signal.
The Mackie is working fine, no mutes on, etc but for some reason the track is NOT getting the signal.
I went in my MBP, and made sure nothing is set to the Duet. Everything reads Mackie Onyx 1640i but NOTHING is being read on the track?
I hope this makes sense. This is driving me CRAZY!
Thanks so much.
Problem with Mackie, MacBook Pro and Apogee
- Tigerbass
私はファズを愛して = I love the fuzz.
- Deltaphoenix
Re: Problem with Mackie, MacBook Pro and Apogee
Are the tracks armed? I really know nothing about this set-up you have Bro.
- tuffteef
did you set your input and outputs?
i think with logic you have to change which daw your using in the prefs
