Trek 10 knobber special run of 4
weird fx from the Dominican Republic <copilotfx.com>
Moderator: autopilot
autopilot
Post by autopilot »
[youtube]http://www.youtube.com/watch?v=ocapK2gArhw[/youtube]
So i had been talking to a member here for a while about a trek with some options, and after lots of pm, it turned into this:
This is a trek with some variations, for the parallel dry it has a gain knob plus the vol, so you can get more sounds. The pulse width fuzz section is similar but has an extra range knob (so via the footswitch you can go from 2 settings on the fly), plus the oscillation section now has a 4 way rotary switch (the on the side) that turns off the osc and the other 3 fine tune the range of the oscillation so you can get the high pitches plus the low tumbling pulses, the osc knob fine tunes the pitch, and 2 toggles changes the shape and adds the modulation (from the cv jack). There's an extra knob (the one on the back around the in/out/power jacks) that will allow to do some tremolo chops to the pulse width fuzz section. CV/Expression input, ideally you will use the cv out of the broadcast (and will still have the exp out and the knobs to connect other device) or 0-5 CV signal, you can use an expression pedal but a lfo will give you a lot more fun.
The second footswitch is to turn on the modulation (from the input of the cv/exp jack) for trem chops / activate the oscillation / select the 2nd range, in any combination you want since each one is independent.
For those interested the trek alone is $130 (1 available) and $180 with a broadcast (2 available), note both the treks and the broadcast are blemished units (the cases have some scratches and the paint is powder coated but have some variations on the intensity of the color), shipping is $20 to north america or $40 elsewhere (excluding the space)
fuzzonaut
Re: Trek 10 knobber special run of 4
Post by fuzzonaut »
Amazing!
Dat trek!!! :omg:
autopilot
Post by autopilot »
trek+broadcast both are gone
