Portal Blendable Fx loop
Moderator: autopilot
- autopilot
Back in time i wanted to an fx loop with molecule tracking, it was fun but wasnt very friendly or musical viewtopic.php?f=140&t=22712
so that evolve it, into this. A more practical, friendly, musical and awesome machine. You will be able to fade from your dry signal to a wet signal (whatever you have in the loop), each side have a master volume (that can cut or boost the vol) to find the right balance, plus there's an exp jack so you can do it manually, or if you're a crazy dude you can also plug cv to increase the options and create some interesting patterns and be able to replicate it live. But there's more, a toggle switch on the back will change that instead of fading in and out, the wet signal will be always there, and only the dry will fade in and fade out.
here's a pic of the proto
- Bassus Sanguinis
Re: Portal Blendable Fx loop
for once an original approach to the fx looper pedals, I really like the idea!
- Bellyheart
Yes, still in to it still down. That's such a cool idea. Ohnoho just put that double utter stutter out that has an input triggered feedback loop, but this is even better and so far out! Let's do it now!
- skullservant
So awesome!
- autopilot
After some time rocking the portal, i got some sick new ideas for a bigger version, dual loops with pre-gain and vol for each channel, feedback loop option for the amount synced to the expression pedal. So you can go from one loop to the other, the loop you're going increases the feedback loop (you'll be able to select the max amount in the feedback section)
- Bellyheart
Mmmmmm the current version seems groovy. More is cool too.
- Toonster
I once had an idea like this, great ideas always have other people thinking of it.. Can't wait to see and hear some clips
- Bellyheart
- autopilot
I'm gonna release it under another brand (focused on control devices <sequencers. expression splitters, cv control manipulation devices and the like.), thats why the delay with it, trying to save some money so i can start, was hoping for august then before namm now it seems january, but i'm broke at the moment
and have lots of stuff ready but no money to put it out
- sonidero
What's the latest on the Portal??? I like that basic one up there...
- John
- autopilot
email me, they will be available in 2 weeks. Next week (around thursday/friday), i'll have some videos of it in action
- John
Is there a way to make the loop fade in and out instead of the clean?
- autopilot
each side have independent volume control, so if you set the dry to 0, yes you'll be able to fade in/out what you have in the loop or viceversa
- John
