what should i do pwm fuzz? (now with videos)
weird fx from the Dominican Republic <copilotfx.com>
Moderator: autopilot
autopilot
Post by autopilot »
after a lot of the new TMV spins and misfit love (qotsa), i started reworking on a pwm fuzz design i had, so far i have vol, int(pwm sweep), i played a bit adding a triangle lfo to sweep the int (so you can get the movement). So what you'll prefer lfo or exp for manual sweep?
oldangelmidnight
Re: what should i do pwm fuzz?
Post by oldangelmidnight »
My only PWM fuzz experience is the SS/BS Blargg and the only addition I'd like would be a blend knob.
Manual sweep would be fun but your various LFO waveforms would be cool, too. I think we'd need to hear a demo of that to judge.
jmoote
Post by jmoote »
I would love this with EXP control of sweep and yes a clean blend for sure. Better yet, clean volume and fuzz volume knobs for better gain matching with other pedals.
Also, I don't know how necessary it is, but a gate might be nice to have to keep things tight.
-Jeff
bigchiefbc
Post by bigchiefbc »
I think that would pretty cool, Adam. I use the Behringer Bass Synth on mode 9 (I think) for PWM right now, but I'd love to have it in a fuzz.
I think that it absolutely should have an LFO sweeping the pulse width, otherwise it's not PWM. It might seem pedantic, but when people build the PWM fuzz without an LFO, it's not actually PWM at all, it's just a pulse wave. PWM by definition means that you modulate the pulse width.
srsly?
Fuck you.
jmoote
Post by jmoote »
bigchiefbc wrote:I think that it absolutely should have an LFO sweeping the pulse width, otherwise it's not PWM. It might seem pedantic, but when people build the PWM fuzz without an LFO, it's not actually PWM at all, it's just a pulse wave. PWM by definition means that you modulate the pulse width.
While true, I think that flavour of pulse wave fuzz is useful. I'd be happy if there was an LFO on board as long as it can be turned off and the PW swept manually or by EXP.
-Jeff
autopilot
Post by autopilot »
i did 2 videos, one manually by a knob and the other by a triangle lfo, tonight they will be up. i'm thinking a 4knobber with a simple lfo that can be turned of for manual sweep and a bigger expanded version with more stuff. interesting about the clean blend will check what can i do about
autopilot
Post by autopilot »
Manual Sweep
[youtube]http://www.youtube.com/watch?v=wavmEY9Kv8E[/youtube]
LFO
[youtube]http://www.youtube.com/watch?v=J34JsoTzhds[/youtube]
simmerman11
Re: what should i do pwm fuzz? (now with videos)
Post by simmerman11 »
those clips sounded really cool. i'm really looking forward to new info later.
jmoote
Post by jmoote »
Sounds awesome :drool:
I am guessing 4 knobs will be something like Pulse Width, Volume, LFO speed, LFO depth?
-Jeff
autopilot
Post by autopilot »
vol, lfo rate, range (pulse width), i'm thinking on adding a toggle to activate the lfo and the range will then be lfo amount, but need to get a consistent range because with bass and synths is working well, but on guitar the sweeps ends sounding more like a tremolo
oldangelmidnight
Envelope controlled LFO speed?
jmoote
Post by jmoote »
autopilot wrote:vol, lfo rate, range (pulse width), i'm thinking on adding a toggle to activate the lfo and the range will then be lfo amount, but need to get a consistent range because with bass and synths is working well, but on guitar the sweeps ends sounding more like a tremolo
The toggle idea as described sounds good. A clean volume in parallel with the effect would be awesome but I know that's not for everyone. Exp control of any of the parameters would also be great!
Needless to say I want one already :joy:
-Jeff
autopilot
Post by autopilot »
if everything goes to plan, there will be an small version and a large one with more waveforms and options/knobs, i could add by request the clean parallel dry to the small one. I havent experimented a lot with envelopes, i know it could be doable, but dont wait for it for this one at least for now :)
autopilot
Post by autopilot »
lot of progress i'm really happy with results, with the triangle lfo and guitar can get very phaser-esque, dont know why but my first thought after strumming a chord and let ring was MBV. Kinda understood the need for clean blend when there were modulation. Also without modulation lots of different of fuzztones, that convinced me that the small version will be pulse width with exp option and then a large version with lfo and waves and other options
jmoote
Post by jmoote »
This sounds cool enough that I am already planning board space for it.
-Jeff
