Officially, the craziest idea ever
Moderator: D-Rainger
- D-Rainger
I keep dreaming of making a real-time phrase trainer!!!!
Housed in a rocker (wah-type) pedal, full down would be normal (bypass) but as you played through it and tilted the rocker bit, it would graduaalllyyyy sssssllllllllllllooooooooowwwwwwwwww ddoooooooooooowwwwwwwnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn...... Until it froze, looping forever! And you walk off stage leaving it locked in a frozen moment of time...
Hard to build, completely amazing, fairly useless in a band situation, and hard to build. It would be beautiful, and hard to build.
And with a 'lo-fi' option switch!
- bronzetalon
Re: Officially, the craziest idea ever
I'm quite confused as to how this would work. Would it still function as a normal looper?
- jrmy
D-Rainger wrote:...fairly useless in a band situation...
Oh, I don't know about that - there are a number of lunatics around here who would use that in a band situation!
Sounds like a great idea to me... though apparently it's hard to build.
- futuresailors
Officially the awesomest idea to ever be dreamed of in a rocker housing.
- D-Rainger
bronzetalon wrote:I'm quite confused as to how this would work. Would it still function as a normal looper?
It would only loop when it had slowed down so much it was stationary (looping over one little bit).
I'm thinking, then - as you push the rocker back to flat position - it would speed back up to normal (real life) speed.
I mentioned this idea to friend, who said 'yes - and then if you push forwards from there, it'd play all the notes you haven't played yet!!! But really fast!'
- Jenesis
- Toonster
Jenesis wrote:Would this be hard to build?
I guess it is!
but awesome idea!
- D-Rainger
Actually, I've just done it!
(Not really)
(Not really)
- Adoom
I will buy this from you.
I will use it to ruin our songs. Moreso.
I play.
https://linktr.ee/adhamhocaoimh
Wonderful Dealings With: Behndy, lumena, smallsnd/bigsnd, Ryan
BossMann73 wrote:I didn't insult it......I "curated" a "different aesthetic."
- Adoom
I play.
- Achtane
No, man, that was too fast. He said it slows down when it loops. Like this:
Iiii willl buyyyy thiss frroommmmm yyooouuuuuu...
IIiiii wiiilllll uuuussseeee iiiiittt tooooo rruuuiiiinnn oouuurrr soooonnngggssss. Mooooorrrrreeeesssoooooooo.
Yes, definitely.
futuresailors wrote:Officially the awesomest idea to ever be dreamed of in a rocker housing.
Yes, definitely.
- futuresailors
Achtane wrote:No, man, that was too fast. He said it slows down when it loops. Like this:
That's still to fast man...it's more like
Mooooorrrrreeeesssoooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
- STOMPBOXSONIC
I look forward to this creation.
- theactionindex
Useless in a band situation? PHOOEY!
I would be able to create super awesome sounds, with the added bonus of forcing my band to slow down and speed up at random intervals to keep 'em on their toes!
YOU MAKE, I BUY.
YOU MAKE, I BUY.
- bigchiefbc
Bumping this because it's a really fucking awesome idea!
Fuck you.
