Zoom R16 (or similiar) vs Scarlett 2i2
- Errant Tiger
So I've found that I'm REALLY reluctant to use my laptop for anything other than work these days, and that has been hindering my recording. I've been seriously thinking about getting a Zoom R16 (or something similar) to use for recording - I realize I'll still have to work in my DAW (GarageBand) to edit and mix down and stuff, but that'll be OK - and what I'm wondering is how the sound quality of the Zoom (or whatever) compares to going through the Focusrite. I'm just recording guitars and Yamaha Reface synths.
Also interested in alternatives to the Zoom within the same price range, if anyone has any strong feelings.
Thanks in advance, everybody!
Albums: http://reticence.bandcamp.com/releases
Attempts at uncovering a New England Psychedelia: https://www.instagram.com/reticenceband AND https://soundcloud.com/reticenceband/
- Heraclitus Akimbo
Re: Zoom R16 (or similiar) vs Scarlett 2i2
I can't comment more than to say I rented a Zoom R16 for some recording and it was plenty easy to use/understand on a casual basis, so I suspect it'd be even sweeter with some time invested into it. I recorded a combo synths of vocal mics (in fact, it was the Our Way to Fall album linked in my sig) and got what I needed to mix down in audacity.
- Errant Tiger
That's good to know! It sounded good?Heraclitus Akimbo wrote:I can't comment more than to say I rented a Zoom R16 for some recording and it was plenty easy to use/understand on a casual basis, so I suspect it'd be even sweeter with some time invested into it. I recorded a combo synths of vocal mics (in fact, it was the Our Way to Fall album linked in my sig) and got what I needed to mix down in audacity.
- Heraclitus Akimbo
Yeah, I can say it was a pleasantly neutral element in the process, like the good and bad parts weren't at all on the recorder. From a workflow point-of-view, I managed to get a good multitrack recording from a session where I was busy playing, so that's a big plus.Errant Tiger wrote:
Sonically, we were fairly mid-fi, so I can't attest to crystalline clarity but my experience (and even moreso with with handheld zoom recorders) is clean sound in = clean sound out.
- coldbrightsunlight
As long as you're happy with the stereo output of the R16 and aren't looking to track 8 things at once and actually get those into your DAW then I don't see a disadvantage. Not used this specific model but their recording gear usually sounds ok. I assume bouncing more than a stereo track to PC is possible through fiddling around and outputting 4 hard panned pairs of tracks... but this seems like a pain. Given you're comparison was the 2i2 I assume this is fine
I'm a little tempted by these ones myself sometimes.
- friendship
You can do this with the R16. Arm all 8-tracks, and when you're done, put the R16 in card-reader mode with the USB hooked up to your computertron and import the files.coldbrightsunlight wrote:As long as you're happy with the stereo output of the R16 and aren't looking to track 8 things at once and actually get those into your DAW then I don't see a disadvantage.
They can also be linked to double your inputs. A friend of mine has one too, and we linked ours together to record 16 tracks of a live band at his wedding.
- Errant Tiger
I'm actually thinking about the bigger one, the R24, because of the effects. Pretty sure this is going to solve my laptop-related anti-recording issues... it's just a matter of pulling the trigger. And financing.
- friendship
The R16 also has effects--the same as the R24 as far as I know. But personally, I wouldn't get either for the onboard DSP effects. They sound fine, but not great, and they're less fun to use than hardware or even plugins (unless you like programming by menu). If you were doing your mixdown directly on the Zoom, they would be pretty handy, but it sounds like you're going to do that on your computer (I do this, too).
On the other hand, the R24 has 6 channels of phantom power instead of the R16's 2 channels. It also has a sampler, sequencer, and 8 drum/sample pads. I've never used the R24, so I don't know what they're like to use. This review calls the experience "frustrating process at first...but ultimately there is a fair amount that can be done" https://www.soundonsound.com/reviews/zoom-r24 . But if they're usable that's a pretty dope feature IMO.
Also just to note that on both units, if you're using the onboard mics they take up two of your inputs and you cannot select only one--they're both turned on at the same time. Just something to think about if that effects your workflow.
- Errant Tiger
Thank you! That’s all really helpful. It was the sampler/sequencer/drums I meant, actually. And yeah I saw that same review.friendship wrote:The R16 also has effects--the same as the R24 as far as I know. But personally, I wouldn't get either for the onboard DSP effects. They sound fine, but not great, and they're less fun to use than hardware or even plugins (unless you like programming by menu). If you were doing your mixdown directly on the Zoom, they would be pretty handy, but it sounds like you're going to do that on your computer (I do this, too).
We’ll see!
Oh shit! This was not at all clear to me from the advertising and product page - guess it is yet another example of why it's good to Read The Fucking Manual.friendship wrote:You can do this with the R16. Arm all 8-tracks, and when you're done, put the R16 in card-reader mode with the USB hooked up to your computertron and import the files.coldbrightsunlight wrote:As long as you're happy with the stereo output of the R16 and aren't looking to track 8 things at once and actually get those into your DAW then I don't see a disadvantage.
The advertising of "stereo out over USB" presumably only means live streaming as an interface, but I hadn't realised there was a card reader mode!! Thanks for the lesson!
Thylacine Dream
Look into the Zoom Livetrak L series as well—they're what I settled on after an initial interest in the Rs
EJ
Bassed in Los Angeles
@punkcrushband @painbehavior @queeraspunk @puzzytuesday
Good deals: Tom Dalton, lawrence scaduto, Ryan, Dan DubblEwe, multi_s, MaxMaps, ianmarks, cantremember
- Errant Tiger
Thanks! What convinced you?
Thylacine Dream
I can't quite remember the specs on the Rs but I know the Ls have some higher bitrate and resolution options as well as the ability to act as an interface and recorder simultaneously—great flexibility and you'll always have backups of your recordings!Errant Tiger wrote:Thanks! What convinced you?
EJ
Thylacine Dream
The multiple headphone outs are great too
EJ
- John
I am a huuge, HUGE fan of the Zoom LiveTrak L-12. Decent options for sample rate/resolution (up to 24-bit/96kHz), saves to SanDisk, can be used as an interface (although why?) and will never freeze up like a computer. I dump my tracks into Logic Pro and life is easy.
https://www.sweetwater.com/store/detail ... r-recorder
