Hi there,I am looking for one of these two pedals.
I already have a Pharaoh and a Fnord also by Black Arts Toneworks. The Pharaoh is my main dirt box and i'd like to have an alternative to this for my psychedelic doom band.
I'll use it through the """"clean"""" channel of my Hovercraft Falcon
Any recommendation?
Thanks!
Black Arts Black Sheep VS Crown Of Horns
- Norvhell
- interested
- conky
Re: Black Arts Black Sheep VS Crown Of Horns
The Crown of Horns is an opamp muff so it'll sound really close to the Pharaoh. I don't have the Black Sheep, but if I were going for different tones, that'd be the one I'd get out of the two.
- Norvhell
- interested
Actually i am considering the black sheep as the most probable choice for the same reason. But according to the BAT demos this is a pedal to be used in front of an already dirty amp and i cant really tell how it will sound through a "cleaner" amp
Any black sheep owner who can tell more about it?
- Jero
The black sheep is the one that's based on the bee baa, right? They (bee baa) sound great through a clean amp, but I bet would really crush through a dirty one.
Unfortunately I have not tried the Black Sheep yet (but I want to)
- Norvhell
- interested
Yes,it is based on the Roland bee baa with an added 4 way selector knob for depth.
I also watched a few demos of the bee baa and it seemed a bit too "treebly" for doom applications..
- Jero
While I'm inclined to disagree (based on use, not demos), I would venture a guess that's why the depth selector (for bass) was addedNorvhell wrote:Yes,it is based on the Roland bee baa with an added 4 way selector knob for depth.
They certainly can have more sizzle (or treebly
(Again, sorry I don't have experience with the Black Sheep specifically)
- Norvhell
- interested
Jero wrote:While I'm inclined to disagree (based on use, not demos), I would venture a guess that's why the depth selector (for bass) was addedNorvhell wrote:Yes,it is based on the Roland bee baa with an added 4 way selector knob for depth.
I also watched a few demos of the bee baa and it seemed a bit too "treebly" for doom applications..![]()
They certainly can have more sizzle (or treebly) than the standard muddy big muff though. Also depends on which tone notch setting is used...and something that may be pretty rig dependent as well. I think of is as a sort of muff/super fuzz hybrid in sound
Thanks man!
As every BAT pedal it will do the job
Anyway,i'll wait for someone who had a direct experience with it
Cheers!
- Jero
...also, I should edit my earlier comment on the trebly thing...in the scoop/notched setting, you're are right, the beebaa is definitely just that
and I took some time to reacquaint myself with the other BAT pedals you already have, and you might find some overlap to be honest. That's never stopped me, or most people here from getting another type of dirt box though so maybe you should just go for it
- Norvhell
- interested
The badascan is another attracting option... But i dont know, the black sheep has something that intrigues me...
- benjuro
As Conky said, the Crown of Horns (also the Badascan) would overlap with your Pharaoh a bit more than is probably useful, where the Black Sheep is quite a different beast. The four position Depth selector will definitely allow you to tune how big and burly it is, and if anything, I found mine a bit heavy on the bass and needed to crank the tone to get the treble it needed. BAT puts their own spin on the bottom end--a BeeBaa demo is going to give you only part of the character.
It was my main dirt pedal for my bass rig for years. I only used it on single channel amps that weren't producing tons of gain already, an Ampeg V4 and a Sunn Concert Bass, and it has more than enough gain and bottom end for doom. I can't imagine using it on anything but the lowest settings into an amp that's already cooking...like most BAT, it's not a practice amp pedal and needs some good headroom.
