Strat Abuse - What should I do with this guitar?
I picked up this Squier Standard a while back for $50 :snax:
Neck was dirty (grime and edged) so I filed the burs on the fret ends, and cleaned it up real good. The selector switch is finicky...I still need to fix that, and give it a set-up. Action is quite high.
At some point I decided to start cutting and sanding parts off :idk: (maybe a mistake, but whatever, I got bored)...Can't decide where to go from here. Tempted to pull some meat off the lower horn to go with the upper. Might leave the, "well past relic'd and I'm too lazy to finish it" motif...or commit and give it a color stain or something...
Thoughts on that pick guard? Leave the blinding mirror, replace with a diff color, or cover in cool stickers?...I'm leaning towards stickers.
...Kind of want to build a circuit into it, or do some weird pickup stuff :animal:
ps. chiseling that finish doesn't work very well
Re: Strat Abuse - What should I do with this guitar?
21 views and no thoughts? Wrong subforum? Perhaps the hack jobs thread...
:lol: Was gonna comment on it earlier. :idk: Can't really decide what I'd do. :wha?:
I like it other than the chiseling. :idk: That pickguard's gotta go though. :snax:
adamajah
Post by adamajah »
I like what you did to the horn. I'd leave the shape alone now, but ditch the bad relic job look. Sticker it up, and/or paint that baby pink. The mirror pickguard could work if you vandalize it somehow. ;)
Put a jazz bass pickup in it.
Or less stupidly.
Goldfoils.
Or wind your own.
imJonWain
Post by imJonWain »
You need to sand or use a heat gun to get the finish off.
gnomethrone
Post by gnomethrone »
Visual: Just spray slime green over the body as is and do one coat of matte black paint on the pick guard so as you play it your pick scrapes will be reflective.
Guts: got any pickups laying around? Also carve out more room under the pickguard and put a delay in there so you can either twist a knob to change delay time or mash an arcade button as tap tempo and make sweet laser noises.
good dealings here:
Chankgeez wrote::lol: Was gonna comment on it earlier. :idk: Can't really decide what I'd do. :wha?:
The chiseling was a big fail on my part...especially where it leads to the neck plate :no: :facepalm:
I tried the heat gun thing to remove the finish and was using the chisel to help scrape things, which worked for a minute...then crrrack. Not enough heat I guess.
Not something I'm gonna do again either way :idk:
:idea: what if I did one of my "drip" finishes on the pick guard...coming out the pickup holes!
adamajah wrote:I like what you did to the horn. I'd leave the shape alone now, but ditch the bad relic job look. Sticker it up, and/or paint that baby pink. The mirror pickguard could work if you vandalize it somehow. ;)
Thanks! I think I started out wanted to make something between a Musicmaster and a G&L Fallout...but stopped there. I need to clean that area up with some hand sanding, but figured I'd hold off as I assumed I'd eventually finish sanding the whole thing.
I should say, that wasn't my attempt at a relic job. That's was my, work on this for a while, get bored/distracted, go to something else :lol:
Part of me wants to go all the way to wood and stain it. Painting would be easier, or stickers, like you said...My first bass was covered in stickers (naturally), and it was awesome.
goroth wrote:Or less stupidly.
Goldfoils.
Or wind your own.
:cool: that would be neat. I've never used them. I think that middle position is where I'll put some odd pup. It's routed for H/H/H if I remember correctly so I've got options. Bass pickup would be interesting. I think someone did that recently, and had it turned at an angle so the magnets met with the strings better :idea:
imJonWain wrote:You need to sand or use a heat gun to get the finish off.
Thank you for your suggestions. I'm very familiar with the concept of sanding though...that's how I got through the finish in the first place ;) I just never finished
The heat gun shit though is a waste of time IMO, and how that back got all fucked up in the first place.
gnomethrone wrote:Visual: Just spray slime green over the body as is and do one coat of matte black paint on the pick guard so as you play it your pick scrapes will be reflective.
:drool: high five for that one (creature skateboards guitar anyone?) I'm a sloppy ham fisted fool too. That paint will be shredded :animal:
I don't have any extra pickups, but I could mangle whats inside, or get others. Really like the look/idea of arcade buttons. A delay or oscillating fuzz would be killer.
...I like sweet laser noises.
BetterOffShred
Post by BetterOffShred »
Fill those ruts with some titebond and sawdust and sand flush when dry ;) it's only a Squire but no point in tempting a cracked pocket. I think some rudely obnoxious color pattern and arcade buttons could be dope too for sure
BetterOffShred wrote:Fill those ruts with some titebond and sawdust and sand flush when dry ;) it's only a Squire but no point in tempting a cracked pocket. I think some rudely obnoxious color pattern and arcade buttons could be dope too for sure
Titebond while a great glue that I use all the time is IMOP not the best application for that as the way it is suppose to be used to dry properly, epoxy or superglue work better because that will dry harder and are easier to sand smooth and finish over later.
I think you should wait it pink and green, put a music master bass bridge on it, put a single SD invader in the middle spot and tune it tenor :thumb:
Drap finish is an excellent :idea: :!!!: :love:
Thanks dudes! Yea I’m thinking epoxy or superglue is the way I’d go. I’ve done lots of woodwork over the years (not that you could tell from this thing so far :lol: ) and have used that method a couple times.
I checked and the middle position is routed for single coil :grumpy: but I can change that. Would I need to get a different neck? (Or what would be required to make the four string thing work?
Chankgeez wrote:
Jero wrote: :idea: what if I did one of my "drip" finishes on the pick guard...coming out the pickup holes!
I think I’m gonna get an extra guard or two and give it a shot :thumb:
Any more ideas folks? Still pondering on this one.
...I got a couple mini wolf cpu pcbs from Eric...Maybe I'll ditch the extras knobs and use master volume + Mini Wolf :animal:
