Who has a Midnight Amplification Holy Mountain?
ilovedoom @ ilovefuzz
halkaloogie
Post by halkaloogie »
I know the problems people have had with the builder but that aside,I have the opportunity to get one for a good price but I'm not able to play it before hand.Those of you who had/have one, what do you think?
halkaloogie
Re: Who has a Midnight Amplification Holy Mountain?
Really? No one has or has had one and wants to talk about it? Is it really that bad?
:idk:
There'd be a lot more available info if dude hadn't deleted all the posts in his Shark Tank.
odontophobia
Post by odontophobia »
halkaloogie wrote:Really? No one has or has had one and wants to talk about it? Is it really that bad?
dude really burned his bridges here. most people avoided his stuff after that.
benjuro
Post by benjuro »
I had one for a while.
It was burly but not as dirty as I had hoped. Worked well for me stacked with something higher gain, could fill out thinner fuzz nicely and retain its character. I liked it better with my moderate power/volume rig than with the 100 watt full rock jam stack.
jrfox92
Post by jrfox92 »
I found that it tended to sound like adding a blanket over any drive in front of it unless it's jfet based. :idk:
Since I always forget:
benjuro
Post by benjuro »
jrfox92 wrote:I found that it tended to sound like adding a blanket over any drive in front of it unless it's jfet based. :idk:
Hmmm, don't remember exactly what I was using in front of it...I guess the bottom line is it didn't work well enough on its own or stacked for me to keep it around for long.
halkaloogie
I went ahead and bought it, (should be here in a week or so depending on USPS shipping) it was cheap enough there is no reason I can't sell it and get my money back if I don't like it. I'm hoping to run it through my Sunn Beta's effects loop to bypass the Sunn preamp to go along with a Noise Diet Submarine Fuzz acting as a preamp in the other effects loop. I like the Beta power amp with a different preamp, for some reason I find the Beta just doesn't cut through by its self. It gets burred behind the bass in D standard tuning to the point it just completely disappears unless i crank the volume, but with different poweramps its an amazing stereo(ish) rig. Right now I'm using the preamp section from an Orange cr120 into the Sunn with the submarine which sounds great but I really hate dragging two heads around to gigs which I guess is good as a backup but I've never needed it as everything is solid state so I'm really hoping the Holy Mountain will replace the orange.
odontophobia
halkaloogie wrote:I went ahead and bought it, (should be here in a week or so depending on USPS shipping) it was cheap enough there is no reason I can't sell it and get my money back if I don't like it. I'm hoping to run it through my Sunn Beta's effects loop to bypass the Sunn preamp to go along with a Noise Diet Submarine Fuzz acting as a preamp in the other effects loop. I like the Beta power amp with a different preamp, for some reason I find the Beta just doesn't cut through by its self. It gets burred behind the bass in D standard tuning to the point it just completely disappears unless i crank the volume, but with different poweramps its an amazing stereo(ish) rig. Right now I'm using the preamp section from an Orange cr120 into the Sunn with the submarine which sounds great but I really hate dragging two heads around to gigs which I guess is good as a backup but I've never needed it as everything is solid state so I'm really hoping the Holy Mountain will replace the orange.
Don't want to crank the volume? Hate carrying two heads around?
How decidedly un-doom of you.
:P :P
Hope it works out, man.
halkaloogie
Yeah I'm getting old so until I find me some roadies I'm trying to pair down the rig. The Sunn/Sleep doom guitar wall looks cool but fuck it's a downer to move around and set up multi-amp rigs.
odontophobia
halkaloogie wrote:Yeah I'm getting old so until I find me some roadies I'm trying to pair down the rig. The Sunn/Sleep doom guitar wall looks cool but fuck it's a downer to move around and set up multi-amp rigs.
I feel you, dude.
John Matrix
Post by John Matrix »
halkaloogie wrote: for some reason I find the Beta just doesn't cut through by its self.
I had this same problem. I put an EQ pedal in the effects loop and it helped a lot. Might be something worth trying if you like the distortion sound of the Beta.
~ bands I am in ~
halkaloogie
I was doing that for a while with great results too but then I started running is as a stereo(ish) rig running different pre-amps into each effects loop and have been really liking it. As a three piece band I find it fills the sound out better this way too.
Stamnes
Post by Stamnes »
I have one but I can NEVER get them to sound like any demo's I see on the web. im a noob
halkaloogie
I was away and didn't get a chance to properly try out the holy mountain till yesterday.
So far I'm on the fence and until I can play it with the band I won't know for sure, but so far so good (I think).
It doesn't have the sound in the demo's unless I put it into an already distorted amp. And so far it doesn't play all that well pushing it with another overdrive or boost. it's noisy and the blanket analogy is apt, but it does sound pretty good going into a fuzz, a good overdrive or an overdriven amp, but I had to drastically change the EQ of what ever I put it into to accommodate it, which sort of makes it an always on kind of pedal (which is Ok because that is what I was looking for).
I don't know if I've ever spent this long dialing in a pedal and trying different combinations of pedals with it to get it to sound good. It's because I really wanted it to work but if I had played it in a store there is no way I would have walked out with it.
I think I got it to a point where it might be OK but I won't know until next weekend when the band starts practicing again.
On the plus side if I do end up getting rid of it, it looks like the price went up on them so maybe I can flip it for a profit.
