Hi.
I'd like to have a way to measure tonal characteristics of pickups while eliminating as many variables as possible - like the guitar and strings for example.
Is there a way to create a measuring signal akin to white noise for a magnetic pickup?
thanks
equivalent of white noise for magnetic pickups?
- AC128
- kosta
Re: equivalent of white noise for magnetic pickups?
Very interesting. Could you use an electric screwdriver or drill to disrupt the pickups' magnetic field? Or to twirl a thin piece of steel over the pickups at a uniform height?
How are you measuring the output of the pickups to capture the tonal information? On a scope?
- AC128
hey kosta,
yes I was also thinking of a drill or something with a electric motor
I would record the output and use a frequency analyser to visualise it like this:
- kosta
I'm into it. I wonder if a small, exposed electric motor would generate enough of an electric pulse to function as a "tone generator" of sorts. Thinking of the type of small motor that might be found in a slot car or something.
Interesting thread on the Seymour Duncan forums: http://www.seymourduncan.com/forum/show ... y-analysis
- DRodriguez
Ideally, you want to use a sin sine wave frequency sweep rather than white noise for frequency response testing. Maybe that would be easier to reproduce than white noise.
Bring on the waves of sin.DRodriguez wrote:Ideally, you want to use a sin wave frequency sweep rather than white noise for frequency response testing. Maybe that would be easier to reproduce than white noise.
- AC128
