SG killswitch
BitchPudding
SG killswitch
Post by BitchPudding »
Hey all.
Im thinking of continuing to modify my sg further with a arcade button style killswitch. Anyone know how I would go about doing that and where I could buy said switch? Preferably I would like to get one in black or white if possible. Thoughts/recommendations?
YO YO ITS YA BOI
DRodriguez
Re: SG killswitch
Post by DRodriguez »
Sanwa arcade buttons are the standard for arcade buttons. I like the silent line for my weird projects. Hardest part is most arcade buttons are fairly deep, not sure if the SG is deep enough. Also find a 30mm drill bit.
The actual wiring of a kill switch is super easy once you find your switch.
Dr. Sherman Sticks M.D.
Re: SG killswitch
sanwa makes 24 mm buttons too
BitchPudding
Re: SG killswitch
See thats what I was worried about, the depth of the button. Would 24mm be the right depth?
YO YO ITS YA BOI
antennafarm
Re: SG killswitch
Post by antennafarm »
SPST switch,
terminals as follow
[empty] [from switch/hot] [to output]
ANTIMAGIC MEDIA - antimagic.net
DRodriguez
Re: SG killswitch
Actually, most arcade buttons just have 2 terminals. And a better way to wire it a would be [from jack hot] [from Jack ground]. That will eliminate any hum issues you would get.
And I believe the depth on the 24mm buttons is still the same
BitchPudding
Re: SG killswitch
Word. Guess ill have to find some that are more geared for guitars then. Thats ok tho.
YO YO ITS YA BOI
