E.V.A - C.V. Generator
Moderator: spruce_moose
spruce_moose
Post by spruce_moose »
Have been working on miniaturizing the Lightning Wave C.V. functionality for a wee bit now.
The hand filing is a tad rough :whateva: But it seems good to go. I'll do another PCB revision, but before I do I was thinking I'd gauge if rechargeable battery compatibility was a thing worth doing :?: I don't think I could ship it containing the cell, but could make it compatible with cells and generic connectors sold at around $7 from model shops (online) in the US or elsewhere. I calculated a minimum of 15 hours use from a 2000mAh and it can charge overnight at 250mA off any standard 9V with enough juice.
It also includes PTC and over voltage / negative polarity protection, so you can't cook it by trying the wrong supply (up to 40V)
Some of the stuff it does:
User-created controlvoltage LFO waveforms - presets x5
255 stage step sequencer
0-5V output/input range
Tap tempo & touchsensor
Sync input/output
Inverted CV output
Subdivision sync input changeable from 1/1 to 1/8
Control voltage on/off touch sensor
One time triggering to playback waveforms like envelopes
You can thank mysteriousj's coding skills for being able to include all that stuff while keeping it super neat.
Open to any suggestions/criticisms/requests..
DRodriguez
Re: E.V.A - C.V. Generator
Post by DRodriguez »
That is amazing.
The rechargeable battery is a great idea, not something I personally would use. But I can imagine applications where it would be quite handy.
The only things I could thing to change would be a toggle to up the 5V to a higher value. And maybe a stomp or a rugged button for the one time trigger stuff.
requests: one shipped to me
For being hand filed and a tad rough, it looks damn good to me.
spruce_moose
I'm not sure what voltages are are preferred? but will look into that.
The BPM input can be internally toggled from V-trig to S-trig, so an external tap tempo switch can be adapted down to 3.5mm.
Will keep you posted when they're good to go :)
DRodriguez
spruce_moose wrote:I'm not sure what voltages are are preferred? but will look into that.
Awesome about external tap! I can leave this at hand height and just tap with my foot!
From my experience, most things are 5v, but every once in a while you run into some oddball stuff.
doralin
Post by doralin »
I'm down for this!
spruce_moose
Made a demo clip here with my MS10 - https://www.instagram.com/p/BOM5KfoAyc3 ... htningwave
I want some your stuff so damn bad!! Everything you put out is superb!!!
Do you have mailing list that says "hey this is for sale now" or something to that effect?
Also my boner!!!
Strange Tales
Post by Strange Tales »
Is this in correlation with 80tape's CV generator? Seems like bad timing haha.
木枯らし // 木漏れ日 // 風に綱は戦ぐ
spruce_moose
Heh nah the 80Tape CV gen is quite extensive and also has a way different interface. I'll still get one for my ms10 and use both of them :)
oldangelmidnight
Post by oldangelmidnight »
Does it do random?
Iommic Pope
Post by Iommic Pope »
I saw this on IG and it got me excited.
Definitely something I want to look into.
spruce_moose
oldangelmidnight wrote:Does it do random?
No, but you can write 255 steps or seconds, so it could probably sound random but would loop eventually.
spruce_moose
Updates to the PCB done!
15 hours from the battery and charges from standard 9V
Iommic Pope
HOT.
jrfox92
Post by jrfox92 »
:drool:
Since I always forget:
