Magick "i" OUT TODAY!!!!!
Moderator: doug deeper
- doug deeper
Magick "i" Envelope Controlled Overdrive out now!
<(o)> <(o)> <(o)> <(o)> <(o)> <(o)> <(o)> <(o)>
- space6oy
Re: Magick "i" OUT TODAY!!!!!
i hate you money.
- neonblack
Yeah man, this thing is rad. I bet this paired with a fuck OD would have some interesting results.
- cherler
I was thinking the exact same thing, this stacked with a fuck OD would be awesome. Looks great man!
- sylnau
Just received mine and it awesome... magical awesome... I'm speechless.
The compressor Inside this thing bring the magik.
Let your demo playin' do the talkin'.sylnau wrote:Just received mine and it awesome... magical awesome... I'm speechless.
hotknife
I want a Demo Tape Fuzz so bad. The Magick i after that. How does it compare to the Overdrive? The Magick must be rad if it kicked your OD.
- sylnau
The Magik "I" is tighter and the EQ (bass and treble) opens up a TON of new sounds/feels.
It is a bit more dynamic too. Less fizzy (if that make sens).
- fcknoise
I missed this pedal earlier but it induced a whole new level of want
- doug deeper
There's a whooping 8 of these in existence now! Get one before it's 10 and you're all just a bunch of posers.
- goroth
So much this.vidret wrote:"bass control is pre clipping" THANK YOU, FINALLY SOMEONE UNDERSTANDS!
- doug deeper
Pre clipping bass control is the best, even if it's just to leave it up full, it generally means the pedal will have the potential to clip the low end.
I like the low end to clip with some cleanish jangle on top.
I've been using the Eye as my main OD since I came up with it, and it's cuts through like no ones business, even using the in between setting on my tele.
- sylnau
Thanks Doug... this pedal is so magical. There is no bad setting.
Sound so good with Electric Yggdrasil in front of it too.
Here's some Magick "i" (amongst others) demoage from Ed Pettersen:
[youtube][/youtube]
[youtube][/youtube]
