Broadcast Supreme
weird fx from the Dominican Republic <copilotfx.com>
Moderator: autopilot
autopilot
Broadcast Supreme
Post by autopilot »
3 independent outs, each out has the option to select if the output is manual (external expression) or the internal LFO. The LFO rate or tap ratio can be controlled via the expression, the main output can switch if its manual or lfo via a footswitch (the other 2 use a toggle), extra toggle to control the range/amount of lfo via the external expression. For those interested the broadcast supreme price is $220.
(192.08 KiB) Downloaded 72 times
Re: Broadcast Supreme
And the saving of money starts now.
RAD Adam!
