Copilot Fx Dryer
Moderator: autopilot
- autopilot
Copilot Fx Dryer
Dryer : its an utility pedal, it allows you to add a dry/clean blend to your setup, it has a main loop and aux loop. You plug your main pedals in the main loop (is always on) and when you click on the switch you'll be able to add dry signal over your main loop signal, both signals are in parallel so you wont overpower/transform anything in your path. The aux loop is if you feel fancy and want to add more stuff to your dry signal, you can bypass whats inside in this loop will only be available when the loop is on. It will retail for $115. Perfect for the shoegazers and people who like to stack a lot of pedals, and want to have some clarity and order in certain parts while keeping the layered sounds. comments, suggestions, are welcome (post on the comments section), your voice/thoughts/feedback is important.
- Attachments
- IMG_20140312_113820.jpg (195.55 KiB) Viewed 5569 times
- skullservant
Re: Copilot Fx Dryer
This looks really awesome! Would love to hear it with a huge chain of pedals
- zRobertez
Dat graphic
KLON KLON KLON KLONTom Dalton wrote:Like a phoenix's butt, it will rise from the asses.
- robapov
- autopilot
email rock and roll vintage they have one in stock, pm to give you the email, but i think in may, i was in the process on updating the site, but my pc crashed with most of the layouts for this and the data for the info, so that is delaying the stuff right now
