new gyroscopes
Moderator: autopilot
- autopilot
new gyroscopes
Going Smaller: the new gyroscope, will be offered in the 125b case size with expression jack to control the rate/ratio via expression pedal or 5v cv, the toggle on the back is for the tap tempo/speed of the lfo. (Those who want the sligthly wider case will have the option to get one, but the stock retailed version will be in this case)
- Attachments
- IMG_20131230_134134.jpg (96.13 KiB) Viewed 7502 times
- sonidero
Re: new gyroscopes
That looks Hawt... Lots of control in a tiny Pretty Box...
- MeSoFuzzy
Re: new gyroscopes
Hey that's what I have, minus the toggle switch! This is a fun pedal, here's something I did with it-
Dry kick from TR-626, trigger out of 626 opening the VCA on the Wretch Machine, Icunt tapped into Wretch Machine's pulser circuit with a bit of modulation from the on board LFO's, two sends off the mixing board used- INFANEM CFS into Boss RPD-10 on one send, Boss RPS-10 into Copilot FX Gyroscope into Boss RSD-10 on the other send channel, outputs of each FX series for the sends goes into their own channel on the mixing board. I only tweak the sends controls for each return channel of the sends and the Gyroscope.
Thanks again Adam!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- autopilot
Re: new gyroscopes
awesome trance jam, try experimenting with an od/loght distortion after the gyro to double the fun
- MeSoFuzzy
Re: new gyroscopes
Word, that will really bring the harmonics outautopilot wrote:awesome trance jam, try experimenting with an od/loght distortion after the gyro to double the fun
Re: new gyroscopes
sonidero wrote:That looks Hawt... Lots of control in a tiny Pretty Box...
- mikeyx13
Re: new gyroscopes
Just pulled the trigger on one of these, so many cool ideas I hear in the demos. I'll have it by next Friday, hope the family won't miss me over the weekend.
- mikeyx13
Re: new gyroscopes
This is a fun device, so many directions to go with it, between this and another pedal I got in a week earlier, I haven't seen much daylight this week. That's for making something that can inspire!
