fuck vs mini
Moderator: smallsnd/bigsnd
goosekevin
fuck vs mini
Post by goosekevin »
i got a fuck the other day and i really fuckin love it, way more than any od pedal i have ever tried
however
i have not bonded with the crackle side really, i cant figure out how to implement it into my playing
would anyone reccomend selling and buying a mini? or alternatively would anyone like to trade their mini for my fuck?
hazelwould
Re: fuck vs mini
Post by hazelwould »
tomlane95 wrote:i got a fuck the other day and i really fuckin love it, way more than any od pedal i have ever tried
however
I would suggest the swap.
The bias allows you to get pretty ragged, and borderline crackly. But in a more controlled way.
I personally love the crackle, but less so as a momentary feature. I like it to be on and then set the threshold low so when I dig in hard it crackles.
stripes
Re: fuck vs mini
Post by stripes »
I have had a fuck for 6ish months, and I'm not exaggerating at all when I say that it has never been turned off. I recently just got a mini, and it's like a whole new world of sound, seriously. I find myself keeping the fuck as a light od/boost and using the mini really as a light fuzz, slightly crackly and cardboardy but with total tonal controllability (TTC).
I would say keep both because ss/bs is the best pedal company I've ever known, BUT if you don't use the crazy side of the fuck/are looking for something more intense than what the fuck can bring, I would go with the mini. But seriously they sound fantastic with each other, too. GOD..
Almonds
Re: fuck vs mini
Post by Almonds »
tomlane95 wrote:i have not bonded with the crackle side really, i cant figure out how to implement it into my playing
I found this true for me as well. I got a mini and sold my fuck and have not regretted it at all.
When you're ready to come back down
I'll be waiting here
All your friends will be around
I promise I'll wait forever
electrical
Re: fuck vs mini
Post by electrical »
Weighing in here... The standard Fuck Overdrive is great as a standalone, if-I-could-only-have-one-dirt-on-my-pedalboard-what-would-I-use? type pedal. Solid core tone, gets really rough and at 'em when you need it to in terms of gain but can also back off dynamically. I use the Mini's EQ section more as a tone sculpting option. Essentially, my Mountain Range is now my always on pedal (giving me a great thick edge-of-breakup tube amp tone), and I have the Mini set with full bias (as "clean" as possible) and the EQ set where I like it, and it gets pushed by the Mountain Range into full-on distortion. I also use the Mini with the TAFM to give it some more cut when I need it to.
If you only have one pedal, make it the Fuck. If you already have other dirt pedals, the MIni is a fine addition.
Right now, I'm running Mountain Range -> Mini -> Team Awesome! Fuzz Machine (then into my delays/verbs), but I wouldn't be complaining if I were only using Fuck OD and TAFM either.
AngryGoldfish
Re: fuck vs mini
Post by AngryGoldfish »
This is making the choice to buy a Mini as well as keeping a Fuck easier and easier. Fuck.
myrrh
Re: fuck vs mini
Post by myrrh »
Think Im also doing that soon....
goosekevin
Re: fuck vs mini
i really want both
Doctor X
Re: fuck vs mini
Post by Doctor X »
i have a mini,
is the mini with the bias max clockwise the same basic drive sound as the fk? (apart from the crackle part)
the treble knob is the same?
and at what bass knob setting on the mini to match the fk bass level?
Sold to: dan_abnormal (3 times), Abanoise, Kayzer, Ragged Trousers, Schlatte
Bought from: McSpunckle, RitalinCupcake, Tendollarcat, Brobee, Ryan, cedarskies, behndy
Re: fuck vs mini
I believe the bias full cw is the standard and that the treble knob works the same.
Regarding the bass knob:
smallsnd/bigsnd wrote:i added an extra knob to the mini-fuck! it's a bass control - basically i added a little (not much really) more bass to the overall circuit and added a bass cut knob. it is PRE-gain, so you do lose a little bit of the gain when you roll of bass (plenty of gain anyways so it doesn't really matter), but you can get treble boost like response out of the circuit now! yesssssss OR simply turn up the bass for a "standard" fuck.
Also, to those thinking of getting the mini because you don't use the crackle, my advice is to do it. The bias knob and bass knob really give you a wider range of sounds and all of them are sweet.
Re: fuck vs mini
Don't even need
Still want
Re: fuck vs mini
Achtane wrote:Don't even need
You don't know that.
Doctor X
Re: fuck vs mini
Post by Doctor X »
kbithecrowing wrote:Also, to those thinking of getting the mini because you don't use the crackle, my advice is to do it. The bias knob and bass knob really give you a wider range of sounds and all of them are sweet.
what about the other way around? if you have a mini and think about getting the fk as well?
i like trimming back the bass knob and dialing back the bias a little to make it more juicy, so is it worth getting a fk for the crackle?
i already have a variety of other ODs and end up rotating them rather than having 10 plugged in at once
... i'm pretty sure i'll get one anyway.... i just have to know what it sounds like
smallsnd/bigsnd
Re: fuck vs mini
Post by smallsnd/bigsnd »
Doctor X wrote:i have a mini,
kb touched on this, but the setting where the mini will match the fuck the most:
bias around 2 o'clock and bass around 3 o'clock.
treble, gain and volume are all the same.
there will be very slight variations from the range of sweep on the bias knob since i set each one up by hand with a two step process - first with a multimeter, then by ear.
the mini has a tad bit more bass than the fuck. adding the bass control to the fuck messes with the crackle control more than i'd like which is why i have chosen to omit it. they've obviously the same pedal at the core, but i think they're capable of pretty different things.
Casavettes
Re: fuck vs mini
Post by Casavettes »
I plugged into the mini tonight at practice
And I love it. Love it!
This is a great introduction into smallsound for me :joy:
