The Cosmichorus v3 Pre-Order Package Partypalooza!
Moderator: Ryan
- Ryan
Re: The Cosmichorus v3 Pre-Order Package Partypalooza!
They're only on when they're turned on.. two separate but identical Cosmichorus pedals with all their controls the same. No difference between them. Both off or both on.
- 01010111
I just got the best idea I've ever had for a pedalboard
- Ryan
Haha yeah? Using both sides of your Cosmi? I haven't quite decided if that's useful or not yet, I can't come up with a situation where it would own... so you go first! *smile*
- 01010111
Ryan wrote:Haha yeah? Using both sides of your Cosmi? I haven't quite decided if that's useful or not yet, I can't come up with a situation where it would own... so you go first! *smile*
I can't ever decide whether to have modulation pre or post dirt, so by using both sides of the cosmichorus I can have both, and using both sides of my muza fd900 in a similar fashion I can have delay/reverb and chorus before and after fuzz without having a bajillion pedals on my board
That is, so long as I'm understanding how the signal routing would work.
- Ryan
Well if you're talking about one mono chain then you'll have chorus before and after dirt at the same time... it's gonna get warbly buddy!
- Eric!
With these ideas, might I recommend using a true bypass looper for one or both instances in your chain, in case you wanna turn one of them off.
Ran this set-up with a pitchfactor for a hinute. Though "micropitch" ain't got SHIT on Cosmichorus
- Ryan
Right! That's what you need to make it more powerful, a looper.. clever balls!
- 01010111
Just tried proof of concept with the muza and found out the muza isn't really true stereo
will have to start looking for a more powerful reverb/delay unit and looper to pair with the cosmichorus.
will have to start looking for a more powerful reverb/delay unit and looper to pair with the cosmichorus.- oinkbanana
I had a mega pedal board plan once to use a true bypass looper pedal and put the L signal of my eventide pedals at the beginning of my chain, dirt in the midle, and then the R signal at the end of the chain. Controlling it with the true bypass looper would let me put the eventide pedals pre or post dirt - exactly as you described
I did some tests and it worked out fine (minus some specific effects that had LR crosstalk).
I never ended up building the board that I had planned because it would have been 52"X30" and dumb heavy.
But the idea is still solid!
I guess now I should sell those 12 stomp bypass loopers i'm never going to use..... maybe not. maybe someday i'll build the Mega Board. hmmm,
now posting as Forrrest.
- Ryan
*whispering voices from all over the room* Build the Mega Board. Build the Mega Board! BUILD THE MEGA BOARD!
- Holy Schnikes
oinkbanana wrote:I had a mega pedal board plan once to use a true bypass looper pedal and put the L signal of my eventide pedals at the beginning of my chain, dirt in the midle, and then the R signal at the end of the chain. Controlling it with the true bypass looper would let me put the eventide pedals pre or post dirt - exactly as you described
I remember that board, you'd posted some mock up pics, 2xRRR on there amongst a giant collection of other awesomeness??
You should post that pic again, for real, I'd like to gaze at it....
- sylnau
Oink... if you need help I'm near.
- Eric!
Ryan wrote:*Expression pedal input for controlling the rate
*CV input for controlling the chorus effect, can also be used with expression pedal for manually sweeping the effect
So, there are two jacks on the side for expression/cv control, yes? Can these jacks be used...simultaneously? It kinda seems like they...cancel each other out.
coulda...been a toggle?
- Helter
Just watched the demo for the v3 again. It was a terrible idea because now my gas fire has rekindled itself. November needs to fly by!
Live your life like a tree.
Incoming
True pedge
- Ryan
Eric! wrote:So, there are two jacks on the side for expression/cv control, yes? Can these jacks be used...simultaneously? It kinda seems like they...cancel each other out. :wha?: :animal: :?: :animal: :snax: :snax: :poke: coulda...been a toggle? :idk: :idk: :trippy: :cool: :group:
Both jacks can be used at the same time, they're totally separate systems with nothing to do with each other. And let's not start the coulda/shoulda design suggestions a few weeks before production, no amount of emoticons will make that not annoying. :group: :group: :facepalm: :idk: :group: :group:
Helter wrote:Just watched the demo for the v3 again. It was a terrible idea because now my gas fire has rekindled itself. November needs to fly by!
Thanks Brad! We're getting close! I'll show you pics of the v3 pcbs next week and on Friday the box finishers assured me that they'll be ready to ship within 2-3 weeks, they're drilled now and go to powder this week.
We're still at about 75 on the pre-order list...
