Seppuku FX
Re: Seppuku FX
Actually chopped the price in half :lol:
Pepe
Re: Seppuku FX
Post by Pepe »
Apparently the seller was successful. But we won't know the last price, I fear.
Pepe at YouTube and Instagram
Christophe
Re: Seppuku FX
Post by Christophe »
Yep. The previous KK on Reverb was last listed at 444 euros... Don't know about the final offer though.
How does this work by the way? For most pedals, you can see the history of all the sales for a pedal, over the last couple of years. Seppuku is too niche for having a history tab on Reverb?
"It's wrong but it works."
Confuzzled
Re: Seppuku FX
Post by Confuzzled »
[youtube]https://youtu.be/LEyoVuG3Jj8[/youtube]
I forgot about UglyCasanova's side by side with the ADDpedals Data error & Icy water. I love my data error.
Dandolin
Re: Seppuku FX
Post by Dandolin »
Confuzzled wrote:[youtube]http://www.youtube.com/watch?v=LEyoVuG3Jj8[/youtube]
yep - classic
never did get around to scoring an IC Water or workalike (or modding a Nux myself) :facepalm:
still sounds great :joy:
to those in the know- what is going on in the IC Water/Data Error? Is the bend futzing with the delay time? Is it a random lfo? Some kind of intermittent pulse? :idk:
Confuzzled
Re: Seppuku FX
yep - classic
After all this time I still cannot embed a youtube video...
I have to check my data error pedal up against UC's to see if theres a difference. I have the Simon the magpie version which is different. I don't know enough about the electronics to tell what the ned is doing. Dan (Dminer) would be able to explain it better.
Dandolin
Re: Seppuku FX
Post by Dandolin »
yeah, embedding youtube can be a bit of a pita, especially on a mobile device
string should look like this: http://www.youtube.com/watch?v=LEyoVuG3Jj8
full url, no s after http and after.com /watch?v= then the unique signifier
mobile urls chop up the url to look more like you.tube and get rid of the watch?v= part
its easier on a computer because you an just block and copy what's in the url bar and erase the s
as for the secret of the IC Water, I guess I can see why folks would want to keep it a secret :mope: :lol:
and now my lappy is about to go down with no reliable power supply until the one i just ordered arrived, so it's the phone for me for a while
expect monosyllabic shitposting :lol:
Confuzzled
Re: Seppuku FX
Dandolin wrote:yeah, embedding youtube can be a bit of a pita, especially on a mobile device
Y'know I copied it from my desktop and dropped it into the tags but I will try again using your knowledge o' jedi master.
I think the main issue is the tight fit inside the enclosure. from what I've seen the bend goes to both sides of the board so for me I don't want to unscrew anything in fear of screwing things up.
fldrvr
Re: Seppuku FX
Post by fldrvr »
Anyone tried/seen evidence of the time core bends on the nux tape core? Curious if the results are similar.
Good deals: Monkey Boy, julius_deane, oldangelmidnight, K2000 (x2), kbithecrowing, Casavettes, leaves turn, psychedelicrelic, nevada, alexsga, sa1126, Invisible Man, foot, solewheelin', hbombgraphics, bronzetalon, Aquietcabin1978, bass_econo, christafarai; (on TalkBass) jazzyitalian, MicG, bufert57, marineman227, karter2000; (on TGP) leray1, Electroman, bigEbeer; (on DIYstompboxes) LucifersTrip, lethargytartare; (on HC) StratsRule07, lfrz93, Firebrand, caeman, bluesthug
Confuzzled
Re: Seppuku FX
I was wondering about that or their multi core? whatever their modulation version is called if they all are the same infrastructure by way of design.
Re: Seppuku FX
Rhys made a bend of the modulation one and called it Pebbles. I had it for a while. It was interesting, but I ultimately don't get on with modulation pedals much so I sold it. This is the only clip of it I have, where it's just doing some weird fluttery thing to a loop: https://www.instagram.com/p/BFZbn1JnDOt ... uyylpz7s7f
I bent a tape core once. Wasn't that interesting because it's just different head combinations instead of actually different delay types like on the time core.
Christophe
Re: Seppuku FX
My Memory Loss is back from Pepe’s, with increased playability ! Super happy with that. The main issue cannot be solved but I can live with it : we found out that, now and then, the ML sort of « freezes », and you have to unplug it and replug it to get the delay working again. That’s just the behavior of the bent circuit.
Happy days, thanks again man !
BetterOffShred
Re: Seppuku FX
Post by BetterOffShred »
Install a momentary soft touch switch NC in the power in line. Can restart it on the fly with a tap
Pepe
Re: Seppuku FX
Post by Pepe »
Christophe wrote:My Memory Loss is back from Pepe’s, with increased playability ! Super happy with that. The main issue cannot be solved but I can live with it : we found out that, now and then, the ML sort of « freezes », and you have to unplug it and replug it to get the delay working again. That’s just the behavior of the bent circuit.
:hug:
Pepe
Re: Seppuku FX
Post by Pepe »
A Diamond Skeleton Octave Drone is up for sale in the Netherlands (75 €):
https://www.marktplaats.nl/a/muziek-en- ... ve-up.html
Did I ever tell you that I absolutely love my Diamond Skeleton Octave Drone with guitar, synth or piano? :hobbes:
