expensive reverbs
Schlatte
Re: expensive reverbs
Post by Schlatte »
oscillofuzz wrote:Not to semi hijack the thread but can any of y'all reverb connoisseurs recommend me some modulated 'verbs? for bass?
I currently use my Digitech Hardwire in one band but can't rip it off that pedalboard for the other band I'm in. Currently using the reverb setting on the EHX Canyon (lol) but it's too straight forward for my tastes and I want to sell this pedal. I like the way my guitarist friend uses the TC Hall of Fame's mod reverb, but I'm not sure if the HoF's voicing is suitable for bass. I've been looking at Walrus Audio's Fathom too, but I'd like to be made aware of some other options. Preferably not as expensive as Chase Bliss or DBA, but I will consider 'em if they sound best. Size and menu diving can be a deal breaker though, so Boss Rv-500 is off the table as it's both.
I'm using two Hall of Fames on Bass and it works perfectly fine. Plus they're usually available cheap used so you can just try it. :thumb:
Blackened Soul
Post by Blackened Soul »
manymanyhaha wrote:But I've never played with that Lexicon so I can't compare.
Here is a quick recording. This is the setting I use most of the time with varying length and mixing
https://soundcloud.com/icebeardrone/reverb-test
NS Design CR5 upright > SWR Grand Prix with Lexicon MPX 500 rack unit in FX loop on large hall
Recorded with a ZOOM H2n
manymanyhaha
Post by manymanyhaha »
I sold the Merc7 a couple years ago so I am going by memory but the reason I sold it is because it does a gorgeous straightforward large space, and that wasn't much use to me, especially at that time. And when modulated, it was reminiscent of early Slowdive.
So I still say that the Merc7 would be worth trying. It may not have a lot of algorithms like other verbs but it does the two it has better than any other compact pedal that I've tried. But I haven't tried the Neunabers either.
Blackened Soul
Yeah that one going off demos does seem to get a nice clean big. I'll keep an eye on that for sure.
I have a Neunabers wet and I liked and used it to good success in a normal band type setting, and I thought it was pretty decent but compared to the lexicon I am running it sounds thin and small.
I mean to be honest I am happy with my setup... it's just the idea of having everything on the board vs board + rack would allow for running in to more amp setups at random :idk:
penelope tree
Post by penelope tree »
oldangelmidnight wrote:
friendship wrote: Anyone use the Boss RV500?
I use the RV500. I like it because of all the under-the-hood control. I set up all these weird commands where I'll have the length set to switch between short and infinite whenever the envelope goes over a certain threshold. And I'll have a lofi modulating pitch shifted thing getting all creepy in parallel.
And I'm no tone dentist but I think it sounds pretty good.
Are the Non Linear and Early Reflections effects any good for MBV type stuff? I assume they would be but I don't really associate Roland/Boss with reverse reverb effects.
Blood_mountain
Post by Blood_mountain »
Not expensive per se, but I recently got a Springsteen'd spring reverb driver pedal from Make Sounds Loudly (well, from someone else who got it from him). The pedal connects directly to a spring reverb tank via RCA cables (similar to the Anasounds Element but without a real clean option, but a better overdriven sound). The one I got is an old version, but his newest one is basically volume, mix and dwell into whatever spring tank you choose. You get some really great, overdriven spring sounds. Check him out on Insta - @makesoundsloudly
cosmicevan
Post by cosmicevan »
I too use a HoF mini. I programmed it be fairly cavernous and set it at like 50 or 75% and then use parallel mixes with an ES-8 to get different flavors off of a theme (light or heavy). My reverb is admittedly the least "fancy" thing on my board, but yeah, it sounds great on bass...which is why I haven't been in a rush to upgrade. I suspect, I'll eventually make the jump to the Red Panda and get all MIDI crazy so I can use it for much more than just reverb, but don't underestimate the HoF on a budget (mini requires you to use the app, but it was a one time deal for me). If you wanna get "fancy" give Iron Ether's Nimbus a look or even an older version of the Red Panda can probably had on the cheap now that they've made a v2?
•○• cosmically yours •○•
oscillofuzz
Post by oscillofuzz »
Took me over a month after asking for recommendations in this thread to finally pick a pedal after watching tons of videos; I ended up ordering a Zoia :lol:
I really wanted to get into the HoF2, because of its feature set plus affordability, and every time I hear it on guitar or keys I really like it, but every time I hear it on bass (including keys playing low notes) I am a little underwhelmed and feel like it might just get buried in a mix. I also tried liking the EHX Oceans, but it had a very noticeable coloration of the dry signal that I don't want to settle for in this band in which I play my TB2000. Next I watched a lot of demos on the Meris M7 and CBA Dark World, but the CBA underwhelmed me as well and thus struck out considering it's price point (the Keeley side just sounds boring in all the available demos). The Meris sounded plain awful to me. I kept noticing a chirpy kind of quality in the sound in every single demo that I just couldn't get over. Scratched as an option. I considered DBA Rooms, but I ultimately feel like every DBA pedal is inflated, both in price and in size, and even though some of the settings sounded good, I didn't think it sounded €470 good, maybe €200 good. I really wanted to like the Context 2, and almost settled for it, but ultimately felt like the modulation was somehow lacking in most modes, even though every mode has its own type of modulation, and modulation is a must in this case (if it wasn't I wouldn't need a new reverb to begin with). Walrus Audio Fathom was a contender for a while but ultimately I felt like the modulation's swirly LFO nature was too noticeable and there wasn't enough control to tame the swirl without essentially removing the mod altogether.
Next I expanded my search into washy delay territory, but the actual The Wash pedal I didn't like. Considered the Lastgasp Transroom but felt like the maximum decay wasn't long enough for my intended use, even though I really liked the pedal's unique character on subtler modulation settings. After seeing Zachary Rizer's Strymon Volante bass demo I was dead set on getting that one, because it can do beautiful echo delay sounds as well as washes that get into reverb territory, but then I saw it was €435, and started second guessing, because it could really only give me delay and reverb sounds, and that together is usable in like 4 songs max. in this band.
If money was no object I would've just gotten the Volante, but it kind of is. Not that I was necessarily against dropping serious coin, or unable to do so, on a great pedal at this time, but if I did I wanted more bang for my buck (and pedalboard real estate) than the Strymon Volante could offer.
So I looked into an old forum fave, the BitQuest, because I remembered I liked its reverb algorithm based on the Knobs demo from 5 years ago. After closer (re)inspection the reverb really would be the only usable algorithm on the box for this specific band, so I continued in the direction of the Organelle (a friend has one), but that wasn't it either for this scenario because it's more of a desktop device (and a huge one at that), and then I remembered the Zoia, which seemed to check all my boxes, and is a lot of bang for the buck (even at €545, which was the cheapest I could find) in a medium sized package. It's currently on its way to me from Belgium and I hope it'll serve me well as reverb + multi fx.
The Howl Ensemble - Bandcamp - Facebook - Instagram - Soundcloud -
Blood_mountain
oscillofuzz wrote:Took me over a month after asking for recommendations in this thread to finally pick a pedal after watching tons of videos; I ended up ordering a Zoia :lol:
That is a seriously detailed and dedicated vetting process! Well done! Not easy to do with GAS clouding your mind! Let us know how the Zoia ends up working for you.
coupleonapkins
Post by coupleonapkins »
Just re-read the whole thread again, and only one person brought up the Dr. Scientist Atmosphere? :wha?:
I don't even like menu diving, but that thing is the only reverb I'll ever have GAS for (except maybe the Meris/Chase Bliss CXM 1978 that will probably best all of these in the Expensive category, and, hence, my pocquettbook).
Cheers to everyone else digging through all these reverbs & their opinions, really :thumb:
Good morning!
backwardsvoyager
Post by backwardsvoyager »
Poly Digit has claimed the top spot for me.
Quad convolution reverb, comes with a bunch of great IRs, limitless possibilities for filtering and effecting the trails..
Definitely a pain in the ass to adjust on the fly, and slow to load presets, so maybe not the best option for live use :idk:
It's kind of crazy that there are so many $400+ reverb boxes on the market now and almost none of them can load impulse responses.
(still want an Atmosphere tho, Dr. S can do no wrong :snax: )
fcknoise
Post by fcknoise »
Very nice rundown but I feel like if you were after a modulated reverb and nobody mentioned the mod setting on the RV-5. But zoia should be super cool for not only reverb but all kinds of stuff
Gone Fission
Post by Gone Fission »
backwardsvoyager wrote:Poly Digit has claimed the top spot for me.
Logidy discontinued the EPSI, which ran for $200. Stereo IR box that loads reverbs or cab responses. Dead simple box because the impulse is the thing. Once you’ve got one box that does this, there isn’t a lot of reason to get one from another company. Probably dampens interest in putting them out.
I dunno, convolution reverbs can sound very real and true but that isn’t what I’m going for most of the time. Even for acoustic guitar. (Blame Steve Tibbetts.)
i'm with Furtkamp, not for the first time (HI, ROB! :hello: )...i'm going to get the Lexicon 500 multi-FX. i need that endless cavern of atmosphere. also, they're $150-200. i'll put it in the rack along with my other rack-mount reverb/FX units: an Alesis Midiverb II (Bloom!) and a Yamaha GEP-50 with an SPX-90 in its effects loop. i use the Yamahas to simultaneously generate a reverb patch and an Early Reflections patch, which makes for some nice room sounds; i edited the hell out of the presets to tune them to my liking. my number one rule for programmable gear is to never, ever use the stock presets.
i need to split the current 6-space rack into two...the reverbs need a case with latching front/rear panels so it's safe to take them out of the house. there's also that the non-reverb processors--a Rane stereo compressor/limiter and what will soon be two Rane SP15 parametric EQs--can all be connected via XLR, while the reverbs all have only 1/4" phone plugs. they'll live in my current rack without covers, since they'll probably never leave the apartment unless i go to track somewhere. then i'll have room to add more studio processing, maybe a 1/3-octave graphic EQ.
manymanyhaha
coupleonapkins wrote:Just re-read the whole thread again, and only one person brought up the Dr. Scientist Atmosphere? :wha?:
Atmosphere is a quality pedal, just wish it was stereo. But sounds great and very user friendly. Unlike other pedals that have knobs that change what they do for different algorithms, the Atmosphere's LCD screen tells you what each knob does. So no more manual or cheat sheet needed nearby. I wouldn't be surprised if Cooper Arcades took some inspiration from it, as far the ui goes.
This is the problem with that pedal, you really have to work on it to get what is desired out of it. But does indeed sound really good.
