Boredbrain Transmutron Dual FX Loop Crossover Filter
Moderator: superanalog
superanalog
Post by superanalog »
Boredbrain is super excited to announce our new product, Transmutron, which is now available for pre-order. It's been about a year in the making, although the idea for this device has been in our conversations for much longer than that. Now it is finally a reality, and we've made it even cooler and more powerful than originally intended. Below is all of the official product info.
We are hoping to get enough pre-orders within August and September so we can meet or ship them earlier than our expected date of Nov 1, 2018.
Thanks for checking it out!
Link to the official pre-order listing on Reverb.com (You can also pre-order on our website)
Link to the official product page on our website
Features:
  • split signal into two frequency bands
  • process with pedals, eurorack and other effects
  • crossover, crossfader and resonant notch modes
  • control splitpoint with CV and expression pedal
  • select between 12, 24 or 48 db/oct filter slopes
  • limit bandwidths with hi & low cut filters
Modes:
  • FISSION: The Splitpoint parameter controls the crossover frequency to define the bands for each FX channel.
  • FUSION: The Splitpoint parameter adjusts the pre-FX level balance between the two channels like a crossfader.
  • FALLOUT: The Splitpoint parameter moves a wide, resonant notch filter across both pre-FX channel signals.
Description:
Are your effects chains suffering from radioactive decay? The Transmutron allows you to combine pedals (and eurorack effects) within its sonic reactor to create new and exciting compounds! Different results can be achieved using one of three modes: Fission (crossover filter), Fusion (crossfader), and Fallout (resonant wide-notch filter).
In the primary mode, Fission, the signal from your guitar, bass, synth, or drum machine is split into separate frequency bands, sent simultaneously to different effects, and then recombined to a single output (or two separate outputs). The Splitpoint parameter can be controlled manually or with an expression pedal, and simultaneously injected with a control voltage (CV) source for extremely dynamic reactions!
In Fusion mode, the Splitpoint instead acts as a pre-FX level crossfader, rather than splitting the signal into separate bands. This allows for less extreme blends, especially when modulating. In the third mode, Fallout, a resonant wide-notch filter is applied to both pre-FX channel signals, cutting a hole and creating a phasing-wah effect when using an expression pedal or LFO to sweep the Splitpoint back and forth.
To further shape the signals sent to your effects, the Transmutron is equipped with dedicated hi and low cut filters. In Fission and Fallout modes, the cutoff frequencies of these filters also define the end-to-end sweepable range of the Splitpoint parameter and its center frequency. The filters have selectable slopes of 12, 24, or 48 db/oct, which also affects the crossover filter, and greatly enhances the resonance of the wide-notch filter. If further separation of the parallel FX channels is needed, a dedicated phase switch is on-hand.
Both FX channels have two sets of sends and returns: 1/4-in for guitar pedals and line-level effects, and 3.5mm for eurorack level processing. For each channel, the 1/4-in and 3.5mm FX loops can be used simultaneously, as they are in series (3.5mm then 1/4-in). The FX sends are half-normalled so they can be used as buffered copies without affecting the returns. Additionally, the 3.5mm FX loops for each channel can be independently switched to pedal/line-level using internal dip switches, which allows for seamless integration with the Boredbrain Patchulator 8000.
How complex the reaction is up to you! From simple tone shaping using only a couple effects, to interconnected combinations of pedals and eurorack modulation madness, the Transmutron is just the tool you need to reactivate your effects!
Additional Features:
  • +10dB pre-FX gain per channel
  • Mix output or individual output of each FX channel
  • Solo cycle footswitch for channel isolation
  • Phase inversion switch to reduce phasing and enhance stereo output
  • Half-normalled FX sends for buffered copies
  • 3.5mm FX loops switchable between pedal and eurorack levels
Here's the the official launch video on YouTube! :tu:
[youtube]http://www.youtube.com/watch?v=bz2OutLlCVo[/youtube]
Re: Boredbrain Transmutron Dual FX Loop Crossover Filter
:yay:
Fuck!
Kent, this is what I was trying to get made for your Secret Satan!
moid
Post by moid »
Wow that's seven shades of awesome right there! It's something I've been trying to build myself, but you have a lot more extras functions I didn't think of... very cool indeed, hope it sells well :)
fuzzisokiguess
Post by fuzzisokiguess »
Thought id pop in to say hello and welcome to the neighborhood. :hobbes:
superanalog
moid wrote:Wow that's seven shades of awesome right there! It's something I've been trying to build myself, but you have a lot more extras functions I didn't think of... very cool indeed, hope it sells well :)
Thanks, yes we are hoping it sells well too. :lol: It's actually been difficult to get the price down but with enough pre-orders we'll have margin to keep going with a second batch. Fingers-crossed.
fuzzisokiguess wrote:Thought id pop in to say hello and welcome to the neighborhood. :hobbes:
Word! Been around for a little while but having our own little space is new. Hoping to use it as a place to see everyone's Patchulator setups too!
oldangelmidnight
Post by oldangelmidnight »
With this, is there a way to send guitar signals to eurorack effects?
codetocontra
Post by codetocontra »
Yeah, super cool that you got a shark tank. You should start a "show us your patchulator setups" thread in here.
superanalog
oldangelmidnight wrote:With this, is there a way to send guitar signals to eurorack effects?
Yes, absolutely! The Eurorack FX Loops are a big part of the feature set. You can send to two different eurorack effects (or processing chains) in parallel then recombine. Even further, you can use the Pedals FX Loops at the same time as they are in series (after) the Eurorack FX Loops on each of the two channels. So in theory you could send Channel 1 to a eurorack wavefolder AND a reverb pedal, and mix with Channel 2 which goes to the FM input of a eurorack oscillator AND to a delay pedal, etc, etc, etc. And of course the CV input is has eurorack written all over it, literally.
The 3.5mm jacks for the Eurorack FX Loops can be switched internally to be at pedal level (for each channel independently) so you could patch directly into the Patchulator, for example, which feeds pedals. We're going to make a video doing exactly this very soon.
codetocontra wrote:Yeah, super cool that you got a shark tank. You should start a "show us your patchulator setups" thread in here.
Yes, will do!
Dandolin
Post by Dandolin »
This is a great thing--I've used a crossover loop before (sfx x&m) and loved it. Great to see another coming to market; really liking the control scheme on this one.... :zen:
Edit: 7 minutes later -- :eek: :drool:
pre-ordering....
order #10666 \m/
:crab:
superanalog
Dandolin wrote:This is a great thing--I've used a crossover loop before (sfx x&m) and loved it. Great to see another coming to market; really liking the control scheme on this one.... :zen:
pre-ordering....
order #10666 \m/
:crab:
Awesome! Thank you. We are going to keep everyone abreast :lol: of the progress as we build the first batch, with photos and videos. Stay tuned.
Dandolin
Post by Dandolin »
:snax: :snax: :snax:
superanalog
Here's another vid we made quickly for some social media, which plays around with the CV input in crossfader mode, modulated by a looping ADSR. So it's basically shifting back and forth in tempo between the Paranormal Fuzz and Golum. Note: these colors are post-effected.
[youtube][/youtube]
Inconuucl
Post by Inconuucl »
I love you for this. oh man oh man this is going to make my bass vi go nuts. :snax:
Inconuucl: :!!!:
rustywire
Post by rustywire »
YES
E
S
