godspeed you black emperor guitar sound on lift your skinny
Re: godspeed you black emperor guitar sound on lift your ski
noisefield wrote:
may the place in the effect chain change somethings ?
Most definitely.
Plus, with so many band members playing, there's a lot going on.
As people've suggested, take a look at their pedalboards from back then for ideas.
Kacey Y
Post by Kacey Y »
The guitar tones on that album are so layered with other instruments/sounds, they probably could be reproduced a dozen different ways and work in a mix. It's never going to sound like the album in a solo guitar situation though, even if you perfectly replicated the gear used in the recording. That album is very arrangement/performance/production driven and the guitars aren't really that distinct. There's so much going on with the picking patterns, fretting hand vibrato, live room amp interaction and production that's indistinguishable from live effects sounds.
Still, you can take what they did use and derive inspiration for your own stuff from it, certainly.
weebles
Post by weebles »
i've always assumed that part of the sound is distortion from being written to analog tape.
ognoy
Post by ognoy »
noisefield wrote:hi !
so in this video sounds are at about 11:30 the guitar in center right and after at about 11:38 we can better hear it
after at about 33:54 center right
after the guitar at center left at about 35:50
then the guitar center right at 52:57 and we can hear it better at 54:31
at 1:05
finally most at the center right guitar saturated sounds
https://www.youtube.com/watch?v=PZwQeZh6rP0
I think it sounds like some element after the amp is clipping. Tape saturation or mic preamp-clipping.
Maybe add some light overdrive at the end of your chain?
ognoy
Post by ognoy »
This may have changed over the years but they sound very similar to their albums live.
Kacey Y
Post by Kacey Y »
Mystery solved
/thread
noisefield
Post by noisefield »
i don't really want to sound like godspeed but i like this sounds
it's something that can be replicate with small sound big sound fuck overdrive i think but i prefer the old ways
maybe it's the addition of a lot of tracks of the same parts / preamp clipping / tape saturation
i question me about this sounds because a lot of new pedals - i think - tries to emulate this kind of stuffs like it's a new thing but this sounds are already there.
resincum
Post by resincum »
noisefield wrote: may the place in the effect chain change somethings ?
i usually play my delay after my overdrive/distortion etc.. but i will try the other place (delay before)
yes try delay/verb into dirt on a loud amp and you will get similar vibes.. 'analog delay' into dirt does it, too. or you can by a rm-1n he he
tremolo3
Post by tremolo3 »
Delays and reverbs hitting tube preamps to saturate the fuck out of it before going fuzz. I'd start there.
In their last 3 records, after the hiatus, they started to use shitload of fuzz pedals and the difference is quite notorious, but same approach.
VREEEEVROOOOOW
Post by VREEEEVROOOOOW »
UglyCasanova wrote:Indeed!
I remember glancing over their setup when I saw them two years ago or so, but all I can remember is that there was a Drone Commander, a CT5, a Barbershop and a Sunny Day Delay. The rest was pretty standard/non-ILF gear. A lot of volume pedals, like ognoy mentioned. :lol:
Good to see I'm not the only one who was at the Oslo gig glancing at the pedals! I'll be heading down there for this year's GY!BE gig too.
Check out my band, Den elektriske salmebok: http://linktr.ee/salmeboka
Sweet! Both me and Eivind August (on the forums) are going! You should let us know if you wanna hang out. :joy:
noisefield
i will try my a80 and my midiverb into some fuzz and overdrives first to see what happen
reckon luck
Post by reckon luck »
That middle slide guitar section in Antennas to Heaven is godly. I had it as my ringtone for all of college.
