Replacement Pot Woes
JonnyAngle
Post by JonnyAngle »
I have a Peavey PA 100 that needs new pots. The old pots are huge and hold part of the PCB in place. I can't find the proper replacement pots, so I'm going to use jumpers. Any suggestions on holding the PCB down?
Looking at the pic they seem normal, but there is a 1/2" spacer that's part of the pot. The actuators are green plastic. Funky!
Photo Jan 08, 9 43 16 AM.jpg (79.12 KiB) Viewed 8279 times
DRodriguez
Re: Replacement Pot Woes
Post by DRodriguez »
Do all the pots need replacing?
Can some of them just be cleaned?
JonnyAngle
DRodriguez wrote:Do all the pots need replacing?
I used a can of spray and it’s 50% better. Uneven tension, grindy, still staticky.
I recently had to offset another mounting point inside of a build, and to do so utilized the pots as mounting points for structural members. You could do something similar with a hole punch and some old beer cans.
JonnyAngle
JonnyAngle
crochambeau wrote:I recently had to offset another mounting point inside of a build, and to do so utilized the pots as mounting points for structural members. You could do something similar with a hole punch and some old beer cans.
I think this is how it’ll go down.
I thought those parts were five leg with the outer two being just structural? Hard to see in the pic, but that fullcompass part didn't look like what I had envisioned.
DRodriguez
You're thinking of the peavey spider pots, those had the structural 4th leg.
frodog
Post by frodog »
This topic is relevant to me, am in the mode of sourcing various parts like pots for different builds... It's the component I'm least sure about.
Read this interesting R.G. Keen article the other day, a little bit wiser for it: http://www.geofex.com/article_folders/p ... tscret.htm
I thought the pots in the OP looked like the ones in my old RAT, but upon closer inspection they do not.
Pepe
Post by Pepe »
For potentiometers you have to use TUNER SPRAY! :success:
Pepe at YouTube and Instagram
Yeah, I always assume this is known, but pots want the stuff that leaves a lubricating film (and modern pot composition can offer up compatibility issues) and switches/tube sockets want "contact cleaner" which evaporates residue free.
Pots have finite lifespans though, eventually they wear out. Crunchy pots blow goats for anything other than harsh noise.
Pepe
Post by Pepe »
I cleaned a more than 45 years old ultra scratchy potentiometer of my dad's old Grundig HiFi amplifier with tuner spray. This was more than 5 years ago. It works like new ever since then without the slightest crackle. In the last 10 years I haven't had the need to replace a potentiometer, except it was really broken due to high pressure or other accidents (that have happened to the previous owners).
JonnyAngle
Pepe wrote:I cleaned a more than 45 years old ultra scratchy potentiometer of my dad's old Grundig HiFi amplifier with tuner spray. This was more than 5 years ago. It works like new ever since then without the slightest crackle. In the last 10 years I haven't had the need to replace a potentiometer, except it was really broken due to high pressure or other accidents (that have happened to the previous owners).
I'll see if I can get some more cleaner and keep going at it.
Full compass says they can get the exact pots. Peavey says they can't, so we'll see if I ever get an order confirmation email!>!>!>!
Pepe
Post by Pepe »
Tell us what you intend to purchase before buying a spray. The right one will be magic!
JonnyAngle
Pepe wrote:Tell us what you intend to purchase before buying a spray. The right one will be magic!
Whatever they have at the hardware store. CDC qd contact cleaner was what I used
