swapping a latch footswitch for a momentary
Dr. Sherman Sticks M.D.
Re: swapping a latch footswitch for a momentary
hey got another dumb question.
so i got these DPDT momentary switches. trying to figure out which lugs are connected when the switch is not pressed and when it is pressed.
i hooked up my DMM, connected the common black lead to the middle lug on the switch.
and connected the red lead to the top or bottom lug.
i have the DMM set to the resistance setting.
when i connect the red lead to the top, the DMM displays 1. when i connect it to the bottom lug the DMM displays 0.
i'm just a lil confused if 1 means the circuit is connected there or if 0 does?
thanks
i think my lil box works!! now i just gotta figure out how to not eff up drilling the holes in the enclosure.
2015-03-08 13.28.22.jpg (89.89 KiB) Viewed 2192 times
Ya just need something to use as a punch.
And then the Unibit is love.
yea i got one of those. my biggest worry was that it wouldn't fit or i would drill the holes wrong.
which….is basically what just happened. fuckkkkk!
KaosCill8r
Post by KaosCill8r »
Dr. Sherman Sticks M.D. wrote:yea i got one of those. my biggest worry was that it wouldn't fit or i would drill the holes wrong.
Measure twice, drill once.
yea i'm an idiot. i like to learn the hard way sometimes.
You could throw it in an old lunchbox.
Or literally anything shielded on the inside and sturdy enough to get stepped on.
yea! i found this lying around my house. it was a passive summer that i never used, so i ripped out the guts and put my lil guy in there and threw on some stickers.
i also bought twice the parts including the enclosure that i bunked just in case but it was real tight in there, i think i have to rethink the layout orientations. vertical might be where its at.
2015-03-09 20.40.02.jpg (101.88 KiB) Viewed 2166 times
