bortlett
Post by bortlett »
That tremolo is sweet. Tremolo is next on my list, but needless to say, it will not be that rad.
eatyourguitar
Post by eatyourguitar »
Mike, I'm curious, what kind of wah pot did you use and why?
Mike
Post by Mike »
I used the pot that was originally in the Variwah. I think it is custom made to match the mechanism. It is a dual gang pot, and runs from 0 into the 800K range. It has a huge dead spot at the beginning of the rotation, and a huge plateau at the end of the rotation. Once it moves off of 0, though, it is linear over its range. When setup right, it covers the entire range of the pot, while leaving plenty of wiggle room to keep the pot safe. It looks like Akai used a trimpot to set the taper.
I am using both halves of the pot. One half is left linear, and one half has a trimpot to adjust the taper. The linear half of the pot controls the wave distort ("shift") when the toggle switch is down, leaving either the top center knob or the tap tempo to set speed. The tapered half of the pot controls the speed when the toggle switch is up, leaving the top center knob to handle wave distort. If I didn't do it like this, all of the fastest speeds were bunched up in the last 10% of rotation. This way, it spreads the fast speeds out over a more useful range, but the treadle still works as expected when controlling wave distort.
I don't get the full range of the LFO with the pot, but I get pretty close. I think it covered something like 0.15V - 4.97V. I lose a small amount of the slowest speeds.
If you were to do this in a regular wah enclosure controlling speed only, I would think a standard wah pot would work well.
Mike
My diy pedal blog: Just one more build...
karmablock
Post by karmablock »
How did you set up the rotary switches?
Mike
Post by Mike »
Waveform is a 1P8T. Multiplier is 2P6T, but you only use one pole. Basically, you make a string of resistors that act as a big voltage divider, and tap off of them for the control voltage.
I made this a couple of years ago to show someone how to setup the waveform rotary, and about what you can expect for the voltages: http://imageshack.us/a/img411/5316/tttr ... ltages.jpg
The resistor values aren't that important, but the ratios are. The two resistors on the end need to be half the value of the resistors in the middle.
For the multiplier, there are six options instead of eight, so you only use the bottom five taps off the resistors. You could combine the top three resistors into one: 5V--[25K]--[10k]--[10k]--[10k]--[10k]--[10k]--[5k]--GND
Mike
Bret608
Post by Bret608 »
I always like sharing here, even if my builds aren't too exciting in the wake of all the awesomeness! This is a Distortion + built on Culturejam's Plus-Dist board. For the diodes, I did one clear glass 1n270 on one side and two black and blue 1n270s in series on the other. It's a pretty awesome assymetrical setup. It gets me those Bob Mould sounds, and that was the goal.
Uploaded with ImageShack.us
Bellyheart
Post by Bellyheart »
Does he still sell pcbs?
ran_dizolph
Post by ran_dizolph »
Finished up my 3rd build last night! No gut shots, but the wiring is getting a bit better. Put a slightly bigger output cap on it, and it sounds awesome!
Bret608
Post by Bret608 »
Bellyheart wrote:Does he still sell pcbs?
This was a run that he did last summer, so I'm not sure. I'd just check in the Buy-Sell-Trade section over at BYOC, or even just PM him. Someone over at Madbean had a a red version of the board, so I suspect there was another run at some point.
LaoWiz
Post by LaoWiz »
skullservant wrote:Posted them in the Dirge Cave, but I figured I would here as well:
FY-2 + DESTROY SWITCH -> TAP TEMPO TREM.
DAN IS AN ETCHING WIZARD.
Dude, you must have a fucking clip. Destroy switch, wtf. And tap temp trem. Badass looking box. Must sound apeshit!
I don't have a clip, I finished it WAY too late to record anything and boxed it up after I tested it :(
Mathias should defintely do a demo!!!!! The destroy switch is a bend on the FY-2 that gives it about a 100% volume bump AND make it sound like it's stacked with a Big Muff!
LaoWiz
Post by LaoWiz »
skullservant wrote:I don't have a clip, I finished it WAY too late to record anything and boxed it up after I tested it :(
Damn, what you do bypass the mid scoop filter?
Connected two points together until it sounded good :idk: hahahaha
Officer Bukowski
Post by Officer Bukowski »
clari(not) clone w/ fuzz on/off switch
:love:
I make pedals. SHARK TANK
Officer Bukowski wrote:clari(not) clone w/ fuzz on/off switch
:love:
Get ready to get sued by Doug. Almost looks better than the real thing.
