Anyone set up a guitar for stupid-low tunings?
gunslinger_burrito
Re: Anyone set up a guitar for stupid-low tunings?
Post by gunslinger_burrito »
MEC wrote:It's a 30" scale using a Tele body with a Dano Longhorn Bass neck.
Looks rad, sounds rad, easy to DIY!
Pre Humbucker
You know if those necks will fit on a strat body? And I assume the two extra holes were just drilled....etc?
MEC
Post by MEC »
foomanfat wrote:So, does a regular guitar nut fit on those Longhorn necks?
The Danelectro necks have screw on nuts the Longhorn neck comes with one preslotted for 4 string Bass.
You can flip that over and cut it for guitar or get a Danelectro Guitar Nut and it will screw right on to the Bass Neck.
You'll just need to widen the slots to fit the strings you are using.
gunslinger_burrito wrote:You know if those necks will fit on a strat body?
You need the guitar to be a 25.5 scale 21 fret.
Teles work best because Teles and Danos both have a square neck end where a Strat is rounded.
You "might" need to widen the neck pocket a bit or shave down the neck to fit in the Tele pocket.
I chose to shave down the neck so if I decided to convert it back to a regular Tele, I could easily swap necks.
Also, you won't have to do any modification to the bridge saddles if you use a Tele 3 saddle bridge.
The Strat bridge could be a pain.
Using the Tele is more about ease than heavy modding.
gunslinger_burrito wrote: And I assume the two extra holes were just drilled....etc?
Yup, the neck comes with 4 tuner holes but they are spaced perfect for you to just drill 2 more between them.
Here are the Neck, Nut and Strings you'll need.
You also need 2 more tuning knobs (PM me and I'll send you some matching ones) or you can just replace them all with a new set.
With a few basic tools you can have a Tele converted to a VI in a couple hours. :thumb:
gunslinger_burrito
RAD! I'm working up some interesting ideas now! Thanks!
Aw man, I didn't know there were pre-slotted Dano guitar nuts, neato.
Are the default tuners actually any good? I didn't even use them.
dooo ittttttttt
This is so :thumb:
I am actually doing another with a Lucite Mockingbird body :thumb:
MEC
Post by MEC »
Mudfuzz wrote:This is so :thumb:
Of course it is, I got the majority of that info from you. :hug:
Mudfuzz wrote:I am actually doing another with a Lucite Mockingbird body :thumb:
Mudfuzz, you rule. :rock:
:hug: Well... I'd rule if I wasn't letting the fact I keep forgetting to buy something to make a nut out of for it hold the whole thing up... can't get the dano nuts no more..
gunslinger_burrito
Ohhhhhhhhhh shit!!!!! Those necks will fit on BC Rich's?! My ONLY hangup with this idea is that I really wanted a more interesting body than a Tele.
MEC
Post by MEC »
:poke:
:picard:
IEatCats
Post by IEatCats »
While it's a bit off topic, I'm actually considering tuning the SG that I've been playing to Nashville, which is actually an octave up on every string but the high E. I figure it'd be interesting to mess around with, because a set of 12 string electric strings are only $10, and I can just swap them for standards if I don't like it.
On topic, if that bass that I have sitting around doesn't get traded, I might bastardize a couple junky instruments to make a Bass VI after reading all this.
The deal is with a dano 30" bass/baritone neck you can do this to any body made to work with a 25.5 scale 21 fret neck :thumb:
IEatCats
Post by IEatCats »
Update: I did in fact start bastard building a bass VI because of this thread.
IEatCats wrote:Update: I did in fact start bastard building a bass VI because of this thread.
You WILL post picts! :joy:
