Top strings/bottom strings pickup splitting
Re: Top strings/bottom strings pickup splitting
Dude?
I always wanted the "Wild Dog" sound.
kosta
Post by kosta »
Dude that is sweet as hell. (Also scary, as that shop is merely a short bike ride away from my apartment...)
A lil dreamy, a lil noisy.
gunslinger_burrito
Post by gunslinger_burrito »
dase wrote:eagle twin dude does this as well doesn't he? I guess it depends on what you're going for. Both he and dude from Local H are more like, bass pickup under the top three strings to a bass amp type setups.
Yeah, that's what got my gears grinding. Though I think for now I'd be looking at a way to just configure the pickups, and not necessarily have multiple outputs. I don't have the wherewithal for anything like Densely does... I'm like 90% happy with the dirt tone I can get out of my rig, but as I like the sludginess of the neck PU, the high strings get kinda lost in the mix if I'm not 110% anal about my playing style. Thus, I was wonderin' about one output with the aforementioned PU split.....these are rad guitars though. I should mention that that extended-scale Mockingbird (?) that Gentry Densely plays is fucking gorgeous....
They've got a Teisco Spectrum on the website MM linked to:
YES! I was just coming in here to suggest that. There is a 4 pup model on Ebay right now for about $200 with a few hours left
skullservant wrote:YES! I was just coming in here to suggest that. There is a 4 pup model on Ebay right now for about $200 with a few hours left
Wow, no bids on it.
(Edit: Just started reading the description. It has a replaced neck from a shorter scale Teisco on it.)
Throw a replacement Mustang neck on it and you'd be golden. Could you imagine that with a Bigsby? Guh
MEC
Post by MEC »
gunslinger_burrito wrote:So. I used to have a G&L Comanche, but I took out the z-coils forever ago in favor of humbuckers. BUT, the weird pickup selection on it got me thinking.... I'm sure there's an option out there like this, but does anyone know of a pickup setup, guitar, or DIY thing where I could have two humbuckers, but split them so that I can get the LOW strings of the neck, and the HIGH strings of the bridge? Make sense? thanks doods :hello:
If the Humbuckers have adjustable pole pieces you can just remove the screws under the strings that you don't want picked up.
I would try removing the bottom two on the neck and the top two on the bridge and leave both in on the middle strings.
The best part about it is nothing is permanent and you can do it all for free without even taking the guitar apart or the strings off. :thumb:
I just tried taking out the pole pieces on my Jaguar's bridge pickup and really didn't notice a whole lot of change- in fact the GBE strings were still being picked up even though the pole pieces of the humbucker weren't there. :idk:
gunslinger_burrito
Hmmm. I like these last two responses.
@Skullservant: your high strings were getting picked up even when just on the bridge setting? There must be some explanation. Did it seem to pick them up normally, or was it muted or the volume lessened at all?
I basically just want to lessen the sludge on the high strings but keep the sludge on the low strings.....or go in those two directions anyways.
Yep, still getting picked up when just on the bridge setting. I'm not sure whats going on!!
gunslinger_burrito
oh, physics.....science and shit?
Haha YES OF COURSE WATSON!!
MEC
Post by MEC »
It may have something to do with having a metal pickup cover. :idk:
Yeah that makes a lot of sense if you think about it. Because the 3 other metal pins are still connected (just slightly) to that metal cover- and could be transferring or diffusing some of their pull across the entire pickup
