I think I'm falling out of love with humbuckers?
- skullservant
Re: I think I'm falling out of love with humbuckers?
DUDE THATS LIKE A PERFECT FUCKING FIT TOO. Looks like you could squeeze the other one in there holy shit dude! Thats awesome
- Achtane
That pickup looks fucking cool too, just a metal plate.
- ryan summit
3 inches
the 4 ring holes
and the teisco holes match up exact
im gonna try it out full power tomorrow night
before i cut the other one out the teisco
there will be 1/2" between them when the other one goes in
the only prob is the clearance is pretty tight
the teiscos dont have the white ground wire
so i stuck it in the screw hole and tightened it down
i was gonna ask first but just went with it cause it worked
solder wouldtn stick
how should i wire the other one in
match colors or reverse
gotta trim the pickgaurd tomorrow as well
im fuckin psyched
thanks so much duders
the 4 ring holes
im fuckin psyched
- Fuzzy Picklez
ryan summit wrote:you inspire me to do great things ILF
i used to despise the internet
its been nothing but good to me this past year
knock on wood
the fake flamed wood that is my tr2
WITH A FUCKING TEISCO PICKUP IN THE NECK!!!!
it sounds fuckin ghostly
havent plugged any peds or cranked it cause my girl says the house is vibrating
and the baby neighbor sllleeeeeepppzzzzz
but she didnt say it when it was still just buckers
huhhuhhuhhuhuhuhteeheehuhuhhahhahhha
now you know
dont fucking tempt me skullservant
ill do it
I love how twisted that is. Bet it sounds rad.
I don't know guys. I like single coils a lot, but humbuckers are nice sometimes.
My mine guitar is a tele with a single coil in the bridge, and a humbucker in neck. That's my favourite combination ever.
The higher output and big warmth of the humbucker, with the clarity of the tele bridge is the best thing ever. Seriously.
I also love having higher output pickups in the neck. I like getting a boost when I switch to the neck. I've been been crazy about this though, so whatever.
But yeah, if I had to pick one, I'd probably go with single coils. They just seem to be able to do so much more.
Different strokes for different folks though. I used to like humbuckers more, and maybe some day I will again.
- ryan summit
a boost when you go to the neck?
i got exactly the opposite goin on
my neck bucker was so lame
hence the mangling^^
- Fuzzy Picklez
ryan summit wrote:a boost when you go to the neck?
Mhmm.
I like it like that. Other way around doesn't make sense to me at all.
And man, have you thought about fitting another one in there since you all that space?
That might be sort of cool.
JamesSGBrown
Humbucker in the Bridge and a single in the neck is perfect! Stops the neck from being all muddy but still has grunt from the bridge for overdrive.
- Bellyheart
After my jet king I never went back to full humbuckers. The strat I had was hss so that was manageable but as you said, "blanket". Humbuckers are too numb for my taste however a buddy's sg has really bright and awesome humbuckers that sound like p90s. So I guess not all are bad.
- Ancient Astronaught
I was in the same boar as you skully, i hated single coils and fenders. I rode the wave of humbuckers getting hotter and hotter, and it got the point where humbuckers were so hot it was like running a tubescreamer in front of your amp at all times. Now I play pretty much nothing except fenders (and one epiphone) with either low gain humbuckers (they work so much better with high gain pedals) or p-90 single coils. I neve thought i would prefer single coils for balls to the wall doom fuzz but my epi V with mean90's is truly insane, its got the low end, the clarity and the sustain. No wonder Soma and Greg Anderson both have p90 equipped les pauls. I am really interested in those GFS HB-sized WRHB's though, I think they would be awesome in my baritone Jag.
- ryan summit
Fuzzy Picklez wrote:ryan summit wrote:a boost when you go to the neck?
Mhmm.
yeah thats the plan
im wanna make sure its kosher,through the stack at the space tonight
before i pull the other pup out the teisco
im a rookie soldereer just want to be sure,while the hole is semi open
tried it out through the vox p-finder at lowlow volume,cause it was like 2am(sounds good)
also waitin on direction how to wire the second one in
whats the minimum amount of clearance,strings-pickup
its gonna be close,maybe a little grindage is in order
(should i move this conversation to diy?)
ryan summit wrote:... while the hole is semi open ...
maybe a little grindage is in order...
That's what she said.
- ryan summit
hey-ooohh
who said anything about abalonees
- skullservant
Ancient Astronaught wrote:I was in the same boar as you skully, i hated single coils and fenders. I rode the wave of humbuckers getting hotter and hotter, and it got the point where humbuckers were so hot it was like running a tubescreamer in front of your amp at all times. Now I play pretty much nothing except fenders (and one epiphone) with either low gain humbuckers (they work so much better with high gain pedals) or p-90 single coils. I neve thought i would prefer single coils for balls to the wall doom fuzz but my epi V with mean90's is truly insane, its got the low end, the clarity and the sustain. No wonder Soma and Greg Anderson both have p90 equipped les pauls. I am really interested in those GFS HB-sized WRHB's though, I think they would be awesome in my baritone Jag.
Yeah dude. I just.... Can't do buckers anymore. I might consider it later on down the road, but I'm with you. I've got a left over full size WRHB I'm deciding what to do with........
- kosta
Put it in the bridge of something? I like HB's in the bridge position.
- skullservant
Yeah, just trying to figure out which guitar to throw it in. It takes a considerable amount of routing for something like my Telemaster or Jaguar
