Molecule tour box
Moderator: autopilot
- autopilot
Molecule tour box
There are 2 spots, already taken (both of them always were pro-molecule tour),
1-cgbg
2-bellyheart
If you want to be in,
-User with more than 100 post
-USA based
-Have a 9v dc power supply center negative (it wont take 9v batteries)
-spend 2/3 days with the pedal and then send it to next address
If there are more than 4 people from canada or Europe, i could make it there once the usa one is done
1-cgbg
2-bellyheart
-USA based
- Bellyheart
- Jero
Re: Molecule tour box
Id like in!
- Ilikewater
My first tourbox, yes please!
- wdinc01
I'd be interested if you would allow me to join.
Achtane wrote:ILF: Instead of reducing the dimensions of the board, just fill it up with pedals until it looks right.
- CBGB
Yay! Love Copilot tourboxes
ILF pedals: DE Eye of God, Mellowtone Wolf Computer, Mellowtone Singing Tree LE, Fuzzhugger Arc Flash Oscillator, DSc Miniberator, Mysterious J boost/cut/tremolo pedal
http://daylightbats.bandcamp.com/
http://soundcloud.com/lawrence-knowle-field-rec
- wsas3
I want in!
Good dealings with: benjuro, hatshirt(2), Eric!, insubordination, theavondon, skullservant, Ilikewater, GardenoftheDead, AndyTran, behndy, JerryTRCD, StopReferencing, philibis, jfrey, bob the robot, Noise..., space60y(x2), jskadiang, Ryan(2), Helter, mordecainyc, many moreChankgeez wrote:True, but you can also use the Klon as a tremolo. Just stomp on the switch as fast or slow as you'd like.
- wsas3
Oh ;__;
- jrmy
I would like to be in, very much, please please please?
- autopilot
-cgbg
-bellyheart
-jero
-ilikewater
-wdinc1
-wsas3
-jrmy
please pm your info, Name, address, email. I'll ship it on monday
-bellyheart
-jero
-ilikewater
-wdinc1
-wsas3
-jrmy
- misc1600
Are we full?
Classy ILF PEPS: Caesar, benjuro, Blindtofaith, the_necropolitan, Cody_Pole, bob the r0bot, Chaosmic, tigerbass, Kbithecrowing, Psyre, Stanimal, Skip, Ilikewater, StopReferencing, StupidDream88, ZZZZZ
- autopilot
misc1600 pm me your info
- autopilot
shipped today to cgbg, there's some settings inside the box, the version i sent is the one with osc, the second footswitch is a momentary to activate the oscillation (it can get loud), i'll update the order before the weekend
- autopilot
here's the manual
some tips: i find best to define your approach, if your playing chords, i find best to let the chords ring or stroke and do arpegios, downstroke the bass notes strings and upstroke the higher strings. If your playing notes making some droney scales playing around the root and some tapping can get you some interesting stutter texture
The knob on the side sets the amount of oscillation of the filter, which freq is set by both filter knobs, when you press the switch it will start the oscillation, the overall volume increases when you do that.
cranking the gain, and using the master, will give you some fuzz/overload tone, setting the int at 0 will cut the stutter
its a crazy pedal, so hope this helps and check the settings and put some of your findings/settings.
- Attachments
- molecule manual.pdf
- (43.29 KiB) Downloaded 512 times
- Bellyheart
