pedals with effects loops
Gigahearts_FX
Re: pedals with effects loops
Post by Gigahearts_FX »
Lovetone Meatball
Lovetone Cheese Source
Lovetone Flanger
Instagram - @gigahearts_fx
Never
Post by Never »
Two old little rack delays:
Ibanez Hd-1500 Harmonizer/Delay (Works even in pitch-shift mode!)
Ibanez dmd-2000 Digital Delay
I think this is a meatball clone:
3leaf Groove Regulator (discontinued, newer and fancier version w a different name is made now)
FX loop on this doesn't work like I expected: Send carries the Input signal only; Input serves as sens/trigger that controls the filter, which applies to Return signal. For example, I can use a stereo delay in the loop, route L-out to a "dry" amp, R-out to Return for a "wet" amp; or I use a drum pattern on Input, which filters a completely different signal coming through Return based on the drum beats' triggers.
Also, Analogman has a fancy Analog Delay with an effects loop! $300+
aens_wife
Post by aens_wife »
Dwarfcraft Mini Van Delay gonna have one...
