skullservant wrote:I have so much stuff going on in my apartment. After I finish up this tube amp I want to sit down with my modular again and actually record. It's been a few weeks since I've been able to sit down with it.
I have been kind of on hold, waiting for this Creature to come so that I can really get the
modular going again. I will be recording stuff very soon too. again, SO EXCITED!
I have a couple of plans for what I have put together, the Audio Interface has a really amazing resonant EQ that is kind of unique, all of the frequencies are 7 steps apart which is supposed to really give an acoustic quality to sounds. The AI also has a preamp, envelope follower, Dual Universal Slope Generator and VCA/Comparator. So I can run a drum machine (or even just the bass drum from my Tempest or whatever) into the preamp take the signal to the ResEQ and EnvFollower, then use the EnvFollower to trigger other things in time with the beat. The Dual Universal Slope Generator is pretty much what the Make Noise Maths is based of off, this module can be an LFO, Envelope Generator, Oscillator,portamento, pulse delay, subharmonic divider, Non Linear Audio Processor… The Creature is a full Serge Voice and is pretty unique. It has a CrossFader, Variable Q Voltage Controlled Filter, TimeGen Oscillator, Smooth/Stepped Generator. The CrossFader has 2 inputs, can be voltage controlled, has the 1/4"out. The VCFQ is THE Serge filter (there are 3 types I think) that is part of the Iconic sound, it has low, high, band, notch outputs that can be used simultaneously, it can be an oscillator. The VC TimeGen Oscillator is wild, it can be 2 oscillators, or it can be 1 oscillator and the rich side can be a Non-linear lowpass filter, Envelope follower, Sub-harmonic generator, Linear/Exponential portamento, Linear/Explonential AR envelope generator, Linear/Exponential ASR envelope generator, Voltage controlled LFO with either triangular or pulse waveforms and lots more. The SSG is also unique, it is a complex multi-functional module to provide various slew and sample functions, S&H, and a ton more like the TimeGen Oscillator.
I have a TON to learn with this little
modular, the Serge philosophy is pretty different to most modulars. Instead of mostly fixed function modules Serge is made of smaller "Function Blocks" that are patched into the modules that I want. It is very wide-open, makes no distinction between CV and Audio (meaning I can use stuff that is normally used to control CV to affect audio signal flow, and I believe vice versa). In this small system, depending on how I patch I have 6 oscillators, 4 or 5 filters, 4 or 5 LFOs, at least 4 EGs, 3 env. followers.
I seriously should be learning new tricks with this set-up for years.
