I've been searching for the easiest DI and silent way to record guitars. I thought I had found the end all be all with the Two Notes Captor, but at this years NAMM 2020 Quilter Labs has decided to come out with a much simpler solution. I quickly bought one and decided to give them both a quick rip. I used a Balaguer Hyperion into a PLX FX Spirytus Distortion and ran it through both rigs using the built in cab sims, The Wall of Sound Plugin and also my own IR. Check it out and see what you think.
