Hell--OOOO
Could you explain me the differences betweeen Tone Reaper and Hoof in terms of tone and use?
Is The Hoof noisy?
Moderator: earthdevice
CORVO78 wrote:Hell--OOOO
Is The Hoof noisy?
Well Dan Auerbach uses a lot of different fuzz tones, so can you be more specific? Thickfreakness has a lot of Soulbender on it, which is a TB MkIII circuit (kinda like the Tone Reaper). Honestly, the Hoof wipes the floor with the muffs that you have. I'd sell both of them and get a Hoof in a heartbeat, but be prepared to get something else too for more variety (unless you're collecting, there's not much point in having 3 muffs on your board).ToddHoodie wrote:Hello Everyone! So, I questions for all of you EQD players out there.
I'm trying to get a certain fuzz tone. Very much like Dan Auerbach from the Black Keys. I just love thick rich Fuzz.
I have a Russian Big Muff and a Little Big Muff. And they're close, but not exactly what I want. I'm considering buying the Hoof Fuzz. But, i have no way to test it out before buying. What do you recommend?
Everything i've read sounds like it's the right one, But all the demos never do it for me. usually people are playing them through Fender guitars or they don't have their tone set like I do on my gibsons. So, it's frustrating.
How would you guys Rate the Hoof Compared to what Fuzz pedals I have now, Am I just missing something?
Also, does anyone use different fuzz pedals together? I have a hard time using any other overdrive or fuzz that is on my pedals board if it comes after my fuzz . Should I be spacing them out more?
Thanks!!!!
Are the ODs you're using buffered? That makes a difference with a lot of fuzzes too.
I'm pretty sure that's buffered -- it's essentially a TS808 right?ToddHoodie wrote:I'm not sure if my OD is buffered. I'm using a Vox Valve-o-Tone It's pretty sweet. It seems like if that is running directly after the fuzz when i click it on, it cuts the fuzz in half and mutes it.
Thanks
FWIW, the Tone Reaper doesn't sound identical to the Soulbender although they're both based on the MkIII. I found the TR to be sweeter, more like a classic MkIII, where the Soulbender is a rawer kinda sound. Try one though and see what you think. It's the right ballpark.
EDIT: One thing: muff is massively mid-scooped, while the tubescreamer has a mid hump. Kinda wonder if they're not just cancelling each other out
Users browsing this forum: No registered users and 10 guests
