Twosome Fixed-Fuzz-Side vers. Fixed Fuzz stand alone
Moderator: blackout_kyle
Postby andisch » Thu Jul 21, 2011 9:34 am
Hi Folks;
try to do my first post and first Question.
i own a fixed fuzz for a several years, and last week i could get a twosome for a nice second-hand-price.
i thought it will be fine, to have a second circuit on my board.
i´m only using a treblebooster and the fixed fuzz, enough for me :-))
first the problem was the Toneknob at the twosome, cause it works reverse; correct?!
but it does not work in the same tonerange then the one from the small Fixedfuzz.
the problem is the twosome has (on the fixedfuzz side) less heights, and i can´t get the same tone like with the fixed fuzz.
is this "normal"?
are they circuits different?
is there a way out for me to use the TS?
Fixed´Fuzz is version 2
thx andisch
andisch
Re: Twosome Fixed-Fuzz-Side vers. Fixed Fuzz stand alone
Postby blackout_kyle » Thu Jul 21, 2011 10:03 am
The Fix'd Fuzz you have is a version 2 and that Twosome uses the Fix'd version 3 circuit. There are some tonal differences and yes the filter control works differently between the two versions.
blackout_kyle
Postby andisch » Thu Jul 21, 2011 12:40 pm
hi kyle
thx for the fast reply.
is there a way to "downgrade" my twosome, to the fixedfuzz version 2 ???
thx
ps. what was ist done for? the version2 to 3 changings??
andisch
Postby hazelwould » Thu Jul 21, 2011 8:02 pm
I had a really early Fix'd and that thing smoked.
hazelwould
Postby flantrax » Sun Aug 14, 2011 4:22 pm
I had a Fix'd Fuzz and upgraded to a Twosome and I found they sounded pretty much the same...I'm sure they vary slightly due to the transistors but they should be in the same ballpark...Kyle and the rest of the guys at Blackout are super helpful...maybe hit him up and see what they say...
flantrax
Return to Blackout Effectors
Users browsing this forum: No registered users and 4 guests
