Dry out on older Whetstone?
Moderator: blackout_kyle
Postby culturejam » Fri Feb 18, 2011 11:08 am
I've got an older Whetstone (#156), and I just noticed there is a "Dry Out" pad on the PCB that is sitting empty. Can I assume that if there were space for another jack that I could just run a wire from that pad to the jack tip lug?
Thanks
Disclaimer #3: I do sporadic, infrequent contract work for Black Arts Toneworks
Check out my photo gear on the cheap site: Tight Camera
culturejam
Re: Dry out on older Whetstone?
Postby blackout_kyle » Fri Feb 18, 2011 4:28 pm
culturejam wrote:I've got an older Whetstone (#156), and I just noticed there is a "Dry Out" pad on the PCB that is sitting empty. Can I assume that if there were space for another jack that I could just run a wire from that pad to the jack tip lug?
Thanks
Yerp. If you can squeeze a jack in somewhere, you can have pseudo-stereo; or at least, dry to one output and vibrato to another output (but only when the vibrato switch is on).
blackout_kyle
Postby culturejam » Fri Feb 18, 2011 5:10 pm
Thanks, Kyle!
culturejam
Return to Blackout Effectors
Users browsing this forum: No registered users and 4 guests
