Cheap components...
garyg
Cheap components...
Post by garyg »
Yeah, one of those self-answering questions really but is there any guide/advice on which components are ok to buy cheap?
As in, maybe obviously, cheap foot switches (two for £2.50 from ebay) don't feel as good and won't last as long as the decent brands but does that go for stuff like diodes too?
eg. 1N34A diodes, my regular (UK based) supplier has them for about £1 each, Tayda for $.28 or I could get twenty for 99p on ebay... (these aren't NOS I'm talking about incidentally). I'm naturally weary of the too-good-to-be-true ebay prices but would the Tayda ones be sourced from the same place, maybe even the UK ones too...?
So, TL;DR: is it ok to be a tight arse with discrete components (within reason).
Cheers.
Scruffie
Admin
Admin
Re: Cheap components...
Post by Scruffie »
Tayda germanium diodes are horribly brittle, I've tried them before and had to throw away probably 70-90% from the glass breaking when bending the leads gently. Also be wary of places selling Schottky diodes with germanium part numbers.
Pick your battles for where you save money, 'rare' parts and hardware are not a place to try and save.
BetterOffShred
Post by BetterOffShred »
I have only ever had one Tayda 1N34 break, but I use other germanium stuff now mostly anyway. I think the only Tayda part I have really been burned on was the 7660 chips.. they all whistle in audio applications.
Caps, resistors, pots, cases, jacks, etc.. go for it I say.
As far as eBay goes I rarely get bunk shit. Recently I got 4/6 of a 4PDT order showed up as 3PDT and were momentary.. but that was $4 and they refunded me 3$..
There's enough Russian stuff coming out of Ukraine Bulgaria and Russia itself that has nearly the same curve as 1N34A (see the recentish thread on Ge diodes at DiySBs) to get pretty close if not nearly exact. :)
It's really going to boil down to the circuits you're building and how important stable operation is. It is safe to assume you're not banging out life critical builds based on the line of inquiry..
Super cheap resistors are going to have terrible thermal drift characteristics, but you can often ignore that if your build is A) not dissipating gobs of power or B) not a tuned or alignment circuit. Generally speaking, an effects pedal is going to remain comfortably within the center area of any temperature tolerance - unless the part in question is used in power regulation. I'd keep the cheap resistors out of amplifiers (and out of tubed circuits in general, unless you go deep enough to plan for any drift).
Cheap caps are often going to have little to no SOA over designated voltages, so selecting caps rated at double or triple your operating voltages might be advisable.
I have little experience with cheap "counterfeit" parts in the actives, but steering clear of bullshit where power supplies or power amplification is concerned should have you okay in terms of magic smoke inhalation. For most analog pedals your power range is small enough that for MOST things you're still in the realm of harmless.
That said, the processes involved in component manufacture coupled with whatever circuit your working on may not sound as good as wish. This is where adjusting the values of the circuit can come into play, but unless you have a scope or a lot of patience that's a subject for another day.
garyg
Post by garyg »
garyg
Post by garyg »
Thanks all, will take all this into consideration next time i'm ordering anything.
crochambeau wrote:It's really going to boil down to the circuits you're building and how important stable operation is. It is safe to assume you're not banging out life critical builds based on the line of inquiry..
(to paraphrase Bill Shankly) My fuzzes aren't a matter of life and death, they're much more important than that. ;) But quite right, I'm just getting back into building after a couple of decades(!) and the landscape's much changed. My stuffs hardly critical (guess I'm more of a noise head than a tone purist) but still don't want to throw money away on cheap stuff that turns out to be crap.
Didn't know that, I have been pondering those cheap packs on ebay too (y'know, 1200 resistors for a fiver or so...)
And then you end up with much bigger caps I guess? Point taken.
Thanks.
eatyourguitar
Post by eatyourguitar »
1N34A are likely to break if you tug on the leads or bend them where they connect to the glass casing. I don't think it is ever possible to have a batch of 1N34A that is so robust that they can have unbreakable glass and immovable leads. buy the cheapest germanium diodes you can find on the whole internet. just make sure you check them with a curve tracer or maybe at least a signal generator and an oscilloscope. the trace of a germanium junction looks completely different on a scope compared to silicon. you can see and hear the difference. I have purchased fake 1N34A but the problem was that I got silicon instead of germanium. the junction failure rate caused by handling and installation was invariant for all germanium 1N34A. this is a trap for young players doing repairs on OEM vintage guitar pedals containing 1N34A. if the diodes must be removed for some reason, they should be tested or replaced before they are installed again.
garyg
Post by garyg »
Thanks for the advice.
As an aside, is there a reason some diodes like 1N34As are housed in glass and not plastic like other diodes? Or is it just historic?
eatyourguitar
glass is an insulator used in vacuum tubes. I would speculate that the mindset of a component manufacturer was to just keep going with the same industry standard materials. a lot of the vintage soviet diodes I have that were manufactured the same year as the 1N34A were actually plastic casing with silicon junction. if I had to guess I would say it looks like polyethylene. I have noticed a lot of the push to innovate in 1967 was done through new diode designs for the soviet military. the americans were working on silicon integrated circuits. the soviets had all the high precision high frequency temperature stable diodes sorted well before we did. we had them too but I think they were probably way more expensive in the US and probably reserved for the small number of radios with very demanding requirements. it could be possible that the soviet diodes were never cheap but they are very abundant and cheap now. there are still huge stockpiles of diodes from that era with basically no documentation at all but very unusual properties on a curve tracer and also very high bandwidth. the plastic casing works great for airplanes and tanks that experience a lot of vibration and possibly shockwave. I would assume that the glass casing and the germanium junction was just the bog standard mass produced part used in many consumer electronics in america. america was pumping money into silicon transistors through bell labs. even today, we use glass in the 1N4148. also consider that the highest bandwidth germanium transistor was a soviet part. the americans would just switch to silicon if they needed something like that.
Bartimaeus
Post by Bartimaeus »
For pedal applications, I think Tayda or even ebay can be perfectly good for resistors, capacitors, and standard diodes. For chips and some transistors I recommend a site like mouser or digikey, although Tayda can be fine for some applications. If you're looking for NOS parts or germanium diodes, I'd go with a specialty pedal parts store like Smallbear. The difference in cost only makes much of a difference if you're building dozens of pedals, and it's worth it to ensure that you're actually getting a part with properties within the desired range.
garyg
Post by garyg »
Thanks.
Another question; I noticed on ebay a lot of Polypropylene 'safety' caps on offer (eg. https://www.ebay.co.uk/itm/50x10-Value- ... rk:30:pf:0). Wondering what the safety bit is about, designed for some kind of suppression role? Is there anything special about them, besides a maybe higher than average voltage rating?
Safety capacitors fail open instead of failing as a short.
I did not see anything on those caps to indicate they are safety caps. I use safety caps on mains filtering (typically in the "death cap" position in old tubed devices), I use Y1X2 caps from a reputable supplier.
For the purposes being discussed here, safety generally makes no difference.
garyg
Post by garyg »
Thanks.
I should point out I always use the good stuff for builds I want to keep etc. Me poking around in what's out there for cheap is more curiosity/gathering a few worthwhile bits and pieces to experiment with. I never touch mains power but would never go cheap on that aspect... :o
eatyourguitar
http://www.pedalpartsplus.com/product-p/4153.htm
http://www.smallbear-electronics.mybigc ... -signal-1/
https://www.mammothelectronics.com/coll ... 1n60-diode
https://www.mammothelectronics.com/coll ... n34a-diode
https://www.mammothelectronics.com/coll ... ucts/1n270
https://www.taydaelectronics.com/diodes/germanium.html
https://www.banzaimusic.com/Germanium/
I just buy them on ebay and throw out the fake ones. or if I get silicon I just label it as small signal silicon and I put it in a drawer. you can rig up a curve tracer or listening test or just test Vf with a DMM. if you get something with a Vf of 0.3 it is likely germanium. if it looks like a small signal glass diode then it is probably a small signal glass diode. you can also look at the data sheet for the curve tracer.
frodog
Post by frodog »
I posted here but deleted because I felt I didn't have much to contribute.. but I've had some weird experiences, might as well share in case others run into the same.
The power jacks you use on pedals, like say those big ones that have the nut on the outside (like on Wizard of Pitch, might be a different brand there), but the ones I've bought have all been flimsy, like you have to make sure the plug is ALL the way in and doesn't move at all for it to work. Have had other power-related problems as well, so now I'll make sure to test any parts like that for polarity/stability before using. Also, I bought this thing on ebay with two alligator clip leads to a standard power jack (didn't have much info on the listing, might have been center positive). Turned out being reverse of what I thought, red is negative, i.e. it reversed the center negative PSU I hooked up to it. Led to much frustration testing (luckily polarity-protected) circuits.
Have also been annoyed by a couple of bad diodes, guess that's not unusual. Germanium I've been lucky with. Ran into a dud A100k (QY) pot the other day as well.
