Space Station Questions
Postby BoatRich » Mon May 16, 2016 5:31 pm
I recently got a Space Station for super cheap, but it's not passing signal. Everything lights up and you can scroll presets but no sound. It seems like it's just input jack issues to me? Which should be easy to fix? Is there anything else it would be that I hadn't thought of?
BoatRich
Re: Space Station Questions
Postby eatyourguitar » Mon May 16, 2016 5:55 pm
how do you know it is the input and not the output?
eatyourguitar
Postby BoatRich » Mon May 16, 2016 5:58 pm
That's a good point.... Let's just say input/output
BoatRich
Postby BoatRich » Mon May 16, 2016 6:12 pm
Okay so I can't get tuner mode to register a note so I'm thinking input or both
BoatRich
Postby Adamadamadam » Mon May 16, 2016 6:59 pm
I'd recommend building/buying an audio probe and poking around at the signal path to find where the signal cuts out. Otherwise there's basically now way to know where the problem lies.
Adamadamadam
Postby eatyourguitar » Mon May 16, 2016 7:12 pm
you are correct then, I would say there is a problem with the input. it starts with an opamp buffer then feeds into a ADC then into some other IC that runs software. it could be the input jack that would be easy. I don't have time to look at it. I just found out that there are specialists that fix and mod these things. check the names mentioned in this video and the links in this PDF. or try posting an "I need help with my xp300" thread on diystompboxes.com
https://mwynwood.files.wordpress.com/20 ... ech-xp.pdf
eatyourguitar
Postby digi2t » Mon May 16, 2016 9:31 pm
All four XP series pedal schematics are in my gallery, here's the shortcut;
http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=47739
Might help you trace the problem.
http://www.deadendfx.com/
digi2t
Postby BoatRich » Mon May 16, 2016 10:10 pm
Thanks for all the help guys!!
BoatRich
Return to DIY Effects
Users browsing this forum: No registered users and 7 guests
cron
