BitQuest at 18v
Moderator: Ryan
BitQuest at 18v
Postby Willem » Sat Nov 28, 2015 12:15 pm
Hi,
I have a new power supply (1 spot cs-7) on the way and I have the opportunity to power a pedal at 18v and I only have the bitquest that could be.
Who powers it like that? Do you feel a difference?
Fuzzonaut about the RM-1N:
"Amp in a box"?
No, there's no amp in there - tone fairies and feedback goblins live inside this box.
Willem
Re: BitQuest on 18v
Postby blakestree » Sat Nov 28, 2015 12:59 pm
I don't think the 18V tap is gonna give you enough power. BitQuest! tech spec says 150mA.
Blake's Tree
blakestree
Re: BitQuest on 18v
Postby Willem » Sat Nov 28, 2015 2:03 pm
blakestree wrote:I don't think the 18V tap is gonna give you enough power. BitQuest! tech spec says 150mA.
yep, you're right, I haven't look about that.
"Amp in a box"?
Willem
Re: BitQuest on 18v
Postby Willem » Sat Nov 28, 2015 3:55 pm
I read 75mA on the manual... ;)
"Amp in a box"?
Willem
Re: BitQuest on 18v
Postby indianDYsummer » Sat Nov 28, 2015 5:06 pm
Well, the BitQuest is a (mostly) digital pedal, so I suspect there is internal voltage regulation to run the pedal properly off a variable power source, so, if the requirement is 150mA at 9V it would pull 75mA at 18V. Also, my guess would be that it'll sound the same.
indianDYsummer
Re: BitQuest on 18v
Postby Willem » Sat Nov 28, 2015 5:27 pm
Manual says 9v 75mA.
"Amp in a box"?
Willem
Re: BitQuest at 18v
Postby indianDYsummer » Sun Nov 29, 2015 12:00 am
Well, sweet. I power mine off a 90mA/9V tap on the PP2 and its been fine. :)
indianDYsummer
Re: BitQuest at 18v
Postby blakestree » Sun Nov 29, 2015 12:15 am
Check out the way cool http://www.drscientist.ca/.
Journey to the BitQuest!
Click on TECH SPECS.
It reads "9VDC @ 75mA, 18VDC @ 150mA".
:idk:
Blake's Tree
blakestree
Re: BitQuest at 18v
Postby goroth » Sun Nov 29, 2015 2:25 am
blakestree wrote:Check out the way cool http://www.drscientist.ca/.
:idk:
The website is correct.
THe manual doesn't mention 18v. I know this by answering this question incorrectly previously :)
gnomethrone wrote:also snagglepuss broke important ground for gay puma visibility
Debut album droppedJan 5. Fuck yeah. http://open.spotify.com/album/0vXjnDeyPNfeXWNvQRYP1H
My band /// Instagram ///Facebook ///
Re: BitQuest at 18v
Postby Willem » Sun Nov 29, 2015 2:37 am
:idk:
You're right! Thanks.
I thought that if you powered a pedal with higher voltage it needed less mA. For exemple that's how you can power a H9, give it 12v and it needs about 100mA less.
The question remains the same (even if it doesn't work for me). Who has tried? Does it change something? Better headroom for the fuzz part only?
Maybe can Ryan help, we'll see tomorrow if he comes online.
"Amp in a box"?
Willem
Re: BitQuest at 18v
Postby Ryan » Tue Dec 01, 2015 4:20 pm
My thinking was Ohm's law.. assuming R is a constant load, if V doubles then I doubles.
The BitQuest goes to 18V more out of convenience than out of sound quality and I don't really think it sounds much different at 18V, give it a try though and see if you do. You won't hurt anything by trying your available outlet and the BQ will let you know if it's not happy.. if you get a loud hum, weird static, weird high pitched noise, weird distortion, if it does anything super weird... it's not happy. If it sounds and works normally, it's happy.
Ryan
Re: BitQuest at 18v
Postby Willem » Tue Dec 01, 2015 5:47 pm
Thanks, I'll try both 9v and 18v. If 18v doesn't work, I'll daisy chain some other pedals.
"Amp in a box"?
Willem
Re: BitQuest at 18v
Postby Willem » Wed Dec 02, 2015 6:28 pm
Ok guys, I received my CS-7 today and tried to power the bitquest at 18v 100mA.
It works perfectly, I tried both power outputs and no hiss/buzz/ Noise problems. I played it on the clean channel and I haven't tried the fuzz side to see if there was a différence.
I played it tonight on rehearsal, still no problems. So I'm happy to be able to use this power output whereas I never had problems with this pedal in a daisy chain though.
"Amp in a box"?
Willem
Re: BitQuest at 18v
Postby blakestree » Wed Dec 02, 2015 6:38 pm
Cool. I'm glad to hear it's workin' for ya!
Blake's Tree
blakestree
Re: BitQuest at 18v
Postby resincum » Fri Dec 04, 2015 9:45 am
18v doesn't increase headroom? shucks
l.u.t.o.//TOO MANY OF US//STAR EATER///RESIN CUM///VISUALS
resincum
Next
Return to Dr. Scientist
