Pop wrote:I have a very small bass board with a tuner > the Elements > Tremolessence > Ditto > Sansamp. I was thinking about replacing the Trem with a BitQuest, mostly for weird loop stuff between songs when my jackass guitar player is tuning BUT SERIOUSLY he's a great guy. But also for a few special things in-song if I want... octaves and ring mod and stuff.
How's the BitQuest fare on BASS GIT?
Thanks!
Sorry I'm so slow to reply here and thanks for checking in! I don't cut any bass through the BQ, I want it be full frequency range so you'll hear the full sounds of the filters, the sample rate reduction, and the pitch shifters.
Probably got a birthday coming up too, right? *smile*
Timm Grimm wrote:Does fine for me.
Now how do you like your Elements for bass?
What a cool board and what a cool band!
Pop wrote:Ah, cool. What settings and sounds do you use the most? Do you keep the tone knob fairly lo?
The Elements is wonderful for bass. It's something I knew would work really well for me, and it does. The mix knob is really key... blends it just right. I use it on high gain exclusively; my amp is already set for some slight overdrive and so is the Sansamp. It's got a lot of low end to it, and you can totally pump it up with the knobs and switches.
The BQ has the same input and output buffers as the Elements, same setup. Awesome to hear you're digging it, thank you very much!
